Question about Sony VAIO PCG-K33 Notebook
Vaio pcg-k33 power cuts off unexpectedly. Cooling fans are broken. Need a guide to open laptop and replace cooling fans.
  • 22 Answers
This over heating issue is a common issue for this model of VAIO Computer. You will get a free service or replacement of parts(Battery) from the Sony Service Center. For more information please follow the link below.
Battery Replacement
Hope this will help you. All the best.
Posted on Sep 20, 2010
How to reset bios password on sony vaio laptop?
Please open you vaio laptop from bellow instruction link.
http://www.insidemylaptop.com/how-take-apart-sony-vaio-vgn-sz-series-laptop/
Follow step 14
You can manege the idea about CMOS battery.
http://www.insidemylaptop.com/disassemble-sony-vaio-vgn-bx-series-laptop/
Follow step 11
But this is your actual model
http://www.insidemylaptop.com/?s=PCG-K33+PC+Notebook
Just remove the Cmos battery And wit 2 minutes again fit the battery .Your password will be soon reset.
Hope it will help you.
Dec 26, 2010 | Sony VAIO PCG-K33 Notebook
I just got my Vaio PCG-K33 operational once again by installing a replacement LCD screen. Now I realize why I was not in a rush to return this laptop to running condition. The cooling fan runs constantly...
VAIO Battery Replacement program
Sep 17, 2010 | Sony VAIO PCG-K33 Notebook
My sony vaio pcg-k33 shuts off by itself when i turn it on. i think its the video card cause the fan turns on and stays on when i turn the latop on. so maybe its over heating. Please help
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Buy a can of compressed-air, and give your computer a "blow-job", because a layer of dust inside your computer is blocking your heat-radiators, and thus is causing your computer to overheat.
May 07, 2010 | Sony VAIO PCG-K33 Notebook
Sony Vaio K33; the fan seems to run all of the time, hot and nois
i had the same problem with my vaio.
when disassembling the notebook: after you remove the metal cover under the keyboard, you'll see three areas covered with black thermal tape. peel back the thermal tape and you should see tightly packed dust buildups in those areas. use a q-tip and vacuum if you can or air duster. be sure to clean the fans as well as the heatsink assembly.
once that is done, your noise level should be reduced by about 60-70%.
if you're still running hot, consider cleaning the old thermal grease off your processor and reapplying a new layer.
Apr 01, 2010 | Sony VAIO PCG-K33 Notebook
Sony pcg-k33 fan is making noises i took comp apart and cleaned fans with brush but noises still exists and are loud and squeeky
that's the actual fan, brushes may need some fresh oil (like wd40), means opening the lappy back up and removing the fan and dropping some oil inside the fan bearing area (where the fan and hub connect)
this should stop the sounds and help the fan move freely.
though this is also a sign that the fan is unhealthy and will eventually need replaced.
hope this helps.
Jan 03, 2010 | Sony VAIO PCG-K33 Notebook
Sony Vaio laptop fan is very loud and continously running
My pcg-k33 was very noisy (fan) so I vacuumed the fan opening with a powerful shop vac. This helped alot. I think that the CPU temperature triggers the fan so keeping the cooling system clean is important. As well, there are openings on the bottom for air so it is important to keep the unit on a surface that doesn't impede airflow (on your lap is a bad idea)
Mar 17, 2009 | Sony VAIO VGN-FJ270/B Notebook
Loud Fan on The Sony Vaio PCG-K33
Get a NotePal by Cooler Master. Go ahead. Google it. Froogle it. Compare prices. and buy. My K33 5 years, running great, noisy as hell
Nov 28, 2008 | Sony VAIO PCG-K35 Notebook
Sony Vaio PCG-FRV25 Cooling Fan Issue?
I was going to suggest overheating before I read your own diagnosis; Yes, sound like the fan, but you can check by opening up and watching it. Or install temperature monitoring software such as Speefan;
If it is the fan it may well be that there is only one possible replacement - officially. But it is usually possible to cannibalize something cheaper to suit your purpose!
Oct 25, 2008 | Sony VAIO FRV25 Notebook
Hard Drive for PCG K33
Any slimline laptop hard drive should work.
Jul 07, 2008 | Sony VAIO PCG-K33P Notebook
Sony VAIO PCG-K33 Notebook Logo
311 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
