Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
My calculator will come on but will not do anything else! HELP
  • kakima Sep 12, 2010
    Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries. Does the calculator turn on and work normally now?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Having gone over a month without a response to my query, I assume the suggested contrast fix solved the problem.
Posted on Oct 19, 2010
My calculator won't turn on the batteries are fresh plz help
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
Feb 13, 2013 | Office Equipment & Supplies
Invalid DIM shows up every time I try to execute a program on my calculator.. or do anything that isn't just normal math problems.. HELP!
You must disable (deactivate) the Statistical Plots
Press [2nd][Y=] to open the STAT PLOTS configurator
Select 4:PlotsOff then ENTER to execute command.
Mar 05, 2012 | Texas Instruments TI-84 Plus Silver...
My calculator is slow, I plugged in 2 + 2 and it took my calculator almost a minute to solve. Help please!
If a foreign object is loged in the Rount IO port, it may short the circuits, making the calculator run slow. Remove any material in the IO port, by blowing air or some other way. Do not insert anything metallic.
Jan 18, 2012 | Texas Instruments TI-83 Plus Calculator
My fx-300es calculator wont do anything with decimals I need to do decimals for a big test tomorrow please help
When a result is displayed as a fraction or a radical (let us just say not in decimal format), you can convert it to its decimal representation by pressing [S=D].
If you do not want anything to do with fraction or radicals, just configure the calculator to use LineIO.
To do so, press [SHIFT][MODE] to open the (setUp) confoguration screen. Choose [2:LineIO].
Jul 13, 2011 | Casio fx-300ES Calculator
I press ON, then i press the number. My problem is the number not appear on the screen. i spoiled my sister's calculator. help me, please!
Are you sure the calculator turns on? Try using fresh batteries, or try removing and reinserting the batteries and see if you get the same result.
Do you see anything at all when you turn the calculator on? Try pressing '2nd', then 'QUIT' (MODE) a few times.
Did you do anything that you think might have broken the calculator?
Mar 30, 2011 | Texas Instruments TI-84 Plus Silver...
Operating slow and won't turn off
I am having this exact same problem. To do a basic calculation like 2 x 5 , you have to hold down each key for about two seconds in order for anything to show up on the screen; then, you have to hold the enter key down for about two seconds to get the answer. CAN SOMEBODY HELP!
Apr 07, 2010 | Texas Instruments TI-83 Plus Calculator
Invalid dim
Turn off your stat plots
2nd Y=
ENTER
Apr 23, 2008 | Texas Instruments TI-83 Plus Calculator
TI-89 Titanium won't let me input anything or just freezes
try changing the batteries. Mine had the same issue and that fixed it. FYI you may also want to change out the back-up battery as well since it is now most likely drained. Hope this helps.
Oct 23, 2007 | Texas Instruments TI-89 Calculator
Calculator Stuck
Hi. I suspect your calculator BIOS is corrupted. Still looking for the download for that though. Do you have a USB link cable? If so, plug in your calc and check your device information. See if anything comes up.
Dec 08, 2006 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
