Question about Samsung HLR5067WX 50" Rear Projection HDTV
When I try to turn on my TV, I hear a click the lamp turns on and the LAMP button begins blinking green. the screen appears to be very very dimly lit, no picture or sound,and it also appears to be flickering. After about a minute or two all operations seem to stop and the STANDBY/TEMP light comes on the power button. Before this problem of not even comming on the unit would appear to turn itself off for 3-5 minutes them come back on.
  • 7 more comments
  • shane theriot Sep 12, 2010
    If balast is bad would the lamp still come on at all? if that wire has 300vdc is
    it good or bad?
  • shane theriot Sep 13, 2010
    I saw or heard no spark on or around the lamp or balast board. Also, no real noise other than the original "click" after pressing the power button.
    Unit is about 4 years old and never have replaced lamp. As I said, the lamp comes on for a minute as the "lamp" butting is blinking green on the power switch. The lamp and fans turn off and the "standby/temp" flashes on the power button. For those 1-2 minutes no picture or sound appears. Is there anyway to bypass the temp sensor temporarly for testing purposes?
    Sorry mybe I confused you. The standby/temp lite dosnt blink it just lites up after the lamp and fans turn off. I did unplug the temp sensor and still did same thing. So, after putting all back together it did come on for a little while the menu screen was clear but the cable picture was all green and white stripped and had good volume. But I went off and is back to original problem.
    Ok thanks. Will try that first. Thanks you are very helpful and I appriciate that.
    What do you think about the green screen the one time it did come on ?
  • shane theriot Dec 06, 2010
    Finally got new lamp installed. Tv works great while veiwing DVD on componet input. However, when I try to watch cable channels through Cable Input the screen is a greenish color with vertical line running down it spaced about 18inches apart. sound good and cable picture is faint.
    Replaced the lamp and Tv works great on DVD inputs. However, when using Cable input the picture is faint, greenish color and has vertical line running down the screen about every 18inches.
  • shane theriot Dec 11, 2010
    replaced buld tv worked fine for about 2 days. now same sympton as before. lamp tries to light for 1 minute then shuts off. when trying to lite it is not real bright.
  • 10,594 Answers
If Standby/Temp is only light that blinks after tv shuts off then it is problem of Temp Sensor that is sending wrong signal to system control about high temp in tv.
There is nothing wrong in tv except temp sensor, it would be mounted on lamp housing, replace it to get tv back in business.
How old is your tv? Did you replaced lamp in tv in last 2-3 years?
Let me know to provide you more technical info about problem.
Thanks.
Posted on Sep 13, 2010
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Sep 13, 2010
    Temp sensor is not costly part and available with Discount-Merchant.com for $20
    Click above link to view image of part and you can get enlarge images by clicking thumb nail image on page.
    Disconnect temp sensor jack from its circuit board and turn On tv, if it still does not power up, put simple wire on both tiny holes of connector to connect it directly and turn On tv to test temp sensor.
    Thanks.
    Yes, blinking light shows error in this tv and solid light of Standby/Temp means tv refuse to turn On and possible cause is Lamp that has not been replaced yet.
    I thought standby/temp light is blinking but it is not so it seems tv does not turn On due to weak lamp.
    I'm not saying lamp is dead or broke but weak that means its reached to end of its working life span and confusing tv system.
    Replace lamp in tv, hopefully it will solve the issue.
    Thanks.
    OK, no problem.
    Let me know if you have additional question.
    Thanks.
    Greenish screen could be due to less amount of back light that lamp provides in dlp tv.
    You know weak lamp can not produce high bright white light thus light engine's generated image can not be projected on front screen correctly.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described the issue seems to be with the ballast that has gone bad and should be replaced. However, before replacing that check if you hear crackling or see a spark from the ballast as you have the back off then it means ballast(which is the power supply source of the lamp) is good, if not then you’ll have to replace the ballast. You can also test the wire that runs from the ballast to the power supply and check if it reads around 300vdc...if it does then you need Ballast. If it’s good then it’s the DMD Board that should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 12, 2010
  • Rylee Smith
    Rylee Smith Sep 13, 2010
    If the ballast is bad the lamp wont come on at all. Also if that reads 300vdc then it is the ballast however, from what you have described the issue seems to be with the Digital board going bad and should be replaced.
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Samsung HL-R4266W 42 in won't turn on
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (from a few minutes to a couple of hours).
Additionally, have you tried powering the unit using another outlet?
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
May 01, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Just got a 46hm95 toshiba for free cause the screen wont show anything. i can hear the fan come on. i am very mechanicly and electricaly inclined and have all things needed to test equipment short of an...
hello When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for
the picture to appear on-screen. See "IMPORTANT NOTICE ABOUT HOT LAMP R
When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for the picture to appear on-screen
in the following situations:
• When the Quick Restart™ feature is set to OFF and you turn the TV off and then on again within a few minutes.
• If the TV is on when a short-term power failure, power surge, or other similar power failure occurs, such that the TV loses and regains
power within a few minutes.
This is a property of DLP TV lamp technology and is NOT a sign of malfunction.
If this occurs, the green LED on the TV front panel will blink (and the red LED will be lit solid) until the TV is finished restarting the lamp
and the normal picture appears. If BOTH green and red LEDs are blinking at a one-second rate, you will need to turn the TV off and then
on again to restart the lamp.
ESTART" on page 8. if this no good check the lamp in side to see if it's not burn't out good luck
regards
shaun
Jun 01, 2010 | Toshiba 46HM95 46" HDTV
Reset lamp hours on sony grand wega
hello
  1. Press "Display" on the remote, followed by the 5 button, then the sound up key, and "Power On." Do this while the TV is in Standby mode.
  2. Step 2 Then press "Jump" 3 times to enter the DE Service menu. The TV screen will display the total lamp time hours.
  3. Step 3 Reset the lamp time by pressing channel 3, then mute, then enter. This will put your lamp counter back to 0.good luck
shaun
Nov 05, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV Does not Turn on
it sounds like the power transformer maybe out on the set.it supplies power to the whole set and it sounds like it only getting partial power.
Jan 17, 2009 | Panasonic PT-52LCX66 Projection Television
Won't turn on. Green power light blinks for 30 seconds and then red lamp light blinks constantly
If the lamp light is lit, it is likely a bad lamp. If you remove the lamp from the set, you will either see shards of glass in the housing and/or a very cloudy reflector (it should look like a mirror). Be sure to use an original Sony lamp as the replacements are trouble makers. Please be sure to rate this solution. Thanks!
Oct 29, 2008 | Sony KDS-60A2000 60" HDTV
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
55 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
