Question about Polaris Pb4 - 60 Booster Pump
My Polaris PB4 Booster Pump is frozen...It hasn't been operated in two year and now it's frozen. It hums but will not spin. Is there any way to free it.
  • John Prohaska
    John Prohaska Sep 13, 2010
    Thank you for posting your question here on Fixya.com. Remove the cover in the center of the motor endbell opposite the pump. Doing so will expose the tip of the shaft and it usually will have a 1/2" flatted end. Use a wrench to try and turn the shaft. If it frees up and runs, great. If not, it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak. If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved! John
  • mbec118907 Sep 15, 2010
    Is there a special technique to removing the center cover?
    Sergeant:
    Champion:
  • 333 Answers
On the end of the motor there is a plastic cap. Pop it off. This is the end of the shaft.On mine there is a slot for a flat head screw driver.You can break it loose with that.I gave mine a shot of WD-40
Posted on Sep 13, 2010
  • John Prohaska
    John Prohaska Sep 15, 2010
    There should be two small sections raised slightly off the endbell flange. Use a small enough flat tip screwdriver and a hammer to tap that opening loose until the cap comes off. Try not to distort the cap too much as you work it free because it is friction fit and you will want to reuse it once you are finished. Reinstall it by tapping it back into place with the hammer.
    Do not use oil, WD40 or any other lubricant in this opening as it is a waste of time and will only make a mess should you try to replace a motor bearing. The bearings used in these motors are sealed so any lubricant you add will not get into the roller balls and will just collect in the cavity behind the bearing.
    John
  • mbec118907 Sep 17, 2010
    I would like to thank both john224 and rnpfloze for their expert input to my solution unfortunely my motor is frozen to the point of no return and must be replace. But the advise was right on time and very accurate. Thanks!
The PB4-60 doesn't fit
They changed the design of the pump a few years ago when Zodiac bought out Polaris. Re-plumbing isn't that hard to do, but if you are not comfortable with it a pool tech or handyman should be able to do it for about $60.
Feb 10, 2014 | Polaris Pb4 - 60 Booster Pump
Humming booster pump
turn off then try to turn back of motor 9/16 wrench turn acouple of times then try if not working bad pump
Oct 04, 2013 | Polaris Pb4 - 60 Booster Pump
Pb4 booster pump is trying to engage. It has a humming noise every 10 to 15 minutes but will not engage
turn off try spinning the back shaft of motor then try if still doesn't work need new pump or motor
Sep 01, 2013 | Polaris Pb4 - 60 Booster Pump
Polaris Booster Pump PB4-60 Overheating
see side of motor make sure wiring correct if ok maybe you got a bad one
Aug 29, 2012 | Polaris Pb4 - 60 Booster Pump
I have a Polaris PB4 booster pump, installed late July 2006, vacuum was running for an hour tonight but I noticed it wasn't moving across bottom of pool normally--wheel was skipping. I shut things down...
The click is the internal thermal overload. Since the pump wouldn't start it overloaded and opened the circuit. Either there is something jammed in the impelller locking the pump up or you have a motor problem. IF it a capacitor start motor, you could have a bad capacitor. Or if it has a starting switch it may not be operating. Start off and be sure the motor turns freely. If you replace capacitor be sure it is same voltage and MFD as the old.Check all wiring connections.
Aug 18, 2010 | Polaris Pb4 - 60 Booster Pump
Pump hums
prime the pump.Put some water in it
May 20, 2010 | Polaris Pb4 - 60 Booster Pump
Booster Pump Model 926515 was leaking and whining for a couple days and now nothing. It hums, then a click and nothing.
It sounds like your bearings have frozen and it's time for a new motor. If you have the right equiptment and can get the bearings these can be changed but if you take it in to have it done it will usually cost as much as a new one. Sorry for bad news, good luck.
Feb 09, 2010 | Polaris Pb4 - 60 Booster Pump
Polaris Pb4 - 60 Booster Pump Logo
1,050 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
