Question about Frigidaire FER311FS Electric Dryer
My dryer is making too much noise and it's not even drying up clothes.
  • 4,323 Answers
Hi
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Posted on Sep 13, 2010
Illeagle
  • 525 Answers
SOURCE: GE Dryer makes an intermittent noise when drum is turning with clothes
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided. Here are some things to look for:
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
MNTECH
  • 1543 Answers
SOURCE: Gas Dryer LDG7304AAE making horribly loud noise while drying
Solution for the Maytag model is most likely to replace the blower wheel. Remove the two screws on the front panel (just a couple inches off the floor) and swing the front panel up to allow you to unhook the top side of the panel from the clips at the very top of the front panel. You do not have to remove the wires, just set the front panel to the side. Blower wheel is at the lower left. The old wheel most likely no longer has a D shaped hole to match the motor shaft, and spins freely. Remove cover. Replace the wheel part number Y303836 for a LDG7304AAE which is held on the shaft with a spring type clamp. Reassemble. Not really very hard to do. On a difficulty scale or 1 - 10, I'd rate it a 3.
Posted on Dec 06, 2008
  • 686 Answers
SOURCE: Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Posted on Mar 04, 2009
pumpkinman
  • 1165 Answers
SOURCE: Ge Dryer making loud rumbling noise
drum bearings are going up
Posted on Jun 19, 2009
  • 479 Answers
SOURCE: Loud Squeaking noise when drying clothes
Might be the issue with the rotor bearings.
2.Might be there is some dust or other thing in rotor drum so please check and clean.
Posted on Aug 11, 2009
I have the duet whirlpool gas dryer - model #GGW9200LW1 and the barrel is making a lot of noise. It seems like one of the inside little cap is loose and the clothes aren't drying. Its taking too many...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 29, 2010 | Dryers
Drying is making grinding noise when clothes are in dryer if no clothes no noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 07, 2010 | Maytag Dryers
Dryer makes a "thumping" sound even when it is running and clothes are not in it. Sounds like a pair of shoes are in there being dried.
heatman101
Oct 18, 2010 | LG DLE3777 Electric Dryer
I have a maytag ldg8200aaw gas dryer. it works and will dry clothes well but makes an extremely loud grinding noise as the drum turns...sometimes it even seems as if it is not engaging...I am trying to...
Your dryer is definitely worth fixing. The blower wheel is plastic 53-0106, These will wear out and get loose. Make noise and the clothes take a long time to dry. Repair Photosa9a0520.jpg
Mar 10, 2010 | Dryers
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryer
Today my whirlpool dryer started making a loud noise. it is drying the clothes but the noise is loud.
Jul 06, 2008 | Kenmore Dryers
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Frigidaire FER311FS Electric Dryer Logo
97 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
