The LCD is barely illuminated, almost dark. - Computers & Internet
  • 2,567 Answers
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Posted on Sep 18, 2010
My lightning got really dark and i can barely see anything,i have to put the frame really up close to see a little bit.im not sure why it got like that.need help
LCD screens have a backlight. When the backlight starts to dim it will eventually completely fail, causing the image to be really dark, barely viewable. You will need to replace the LCD screen, or replace the entire unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 17, 2011 | Philips 6.5-Inch Digital Photo Frame...
Gateway monitor FPD2275W TFT LCD powers on, gateway logo goes on fine with brightness then monitor brightness drops so you can barely see it. Not sure if this is a problem with the brightness setting or...
The back lamps that provide the illumination of the
colors, is shutting down there are feedback circuits when there is a problem
with the lamps it will shut down the lamps. Replacing the lamps should alleviate
this problem. For more information on this email me at Sprint6@zoominternet.net
Dec 22, 2010 | Gateway FPD2275W LCD Monitor
Screen will not illuminate, i can just make out
If you hold a flashlight up to it can you see what is on the screen?
If so then the lcd inverter had gone out.
(That happened to my HP)
Mar 12, 2010 | ASUS Z92M Notebook
My tv screen is so dark can barely see anything , it was a bit flashey for about a week then went out. not just dark but can barely see anything
It is the inverter boards on the LCD panel that are bad. The inverters are what light up the LCD panel. The only way to fix it is to replace the inverter boards but usually they are not available by themselves and only come with the LCD panel.
Oct 11, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
HP Pavillion F1503 screen has gone dark...background is very, very faint, barely able to see/read it. What is the problem? If it is a ''backlight'', then what exact is a backlight, what does it do, is it...
Most of the time in this situation, the problem is due to the backlight going out. However, there are some instances where the inverter cable is bad.
The backlight is the part of the LCD which illuminates the screen. Think of an LCD as having multiple layers. One layer has the image itself on a semi-transparent layer and then behind that layer rests the backlight (usually a florescent bulb) which shines through all other layers to make the image glow and illuminate.
More info can be found here:
http://en.wikipedia.org/wiki/Backlight
As far as replacing the backlight, I always replace the whole LCD itself, which includes the backlight.
Otherwise, you risk ordering the backlight and finding out that it was the connection from the backlight to the LCD that was causing the problem (very possible) and then you would have to order the LCD anyway.
Sep 05, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Sony SDM-HS75 tft lcd monitor
Sounds like you need a new backlight. Check lcdparts.net
May 26, 2009 | Sony SDM-HS75 17" LCD Monitor
Weak or non-existent illumination of viewfinder information
sending the faulty electronic camera back to seller (eBay) thank you George Birrell
Apr 18, 2009 | Contax RTS III 35mm SLR Camera
I just got a Clarion DXZ385USB deck installed, but the screen does not appear blue as in the product pictures. It is dark and barely readable. Dimmer is turned off. Any ideas?
I didn't have to connect the illumination lead. If you have the battery wires(yellow) connected, the screen will light up pretty bright. When I connected the illumination wires(orange), I got the same dim screen light effect.
Apr 17, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
I HAVE ONE SONY MONITOR MODEL SDM HS75.
IT IS SHOWING LED BLINKING FAST NO DISPLAY IF CAN ANY BODY HELP ME TO SOLVED MY PROBLUME.
ASHOK MY CELL NO.09322133048
email.ashoksharma4@gmail.com
Mar 02, 2008 | Sony SDM-HS75 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
