Question about HP PSC 950 All-In-One InkJet Printer
Baud rate How do I change my fax baud rate?
    Genius:
  • 3,587 Answers
It's in the printer settings menu
Posted on May 28, 2008
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
How i change the baud rate
why would you want to change the Baud rate? you don't need to do that.. Ive worked on faxes for over 30 years and never once have I changed a baud rate.. leave it alone..
May 02, 2014 | Samsung SF-560 Plain Paper Laser Fax
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Change baud rate for brother fax
  • Press Stop/Exit.
Change baud rate on okifax 5050
The baud rate is automatically set by the machine when it connects to the remote machine. The machines start at the highest speed and drop down until both machines can send/receive without any errors then they send the pages. You can not manually set the speed.
Buddymc
Feb 27, 2012 | OKI Office Equipment & Supplies
Need to the baud rate how do you do it
Enter Maintenance Mode:
1. Unplug power from rear of Fax machine, hold the Menu button while plugging power back in. Continue to hold the Menu button until "Maintenance" appears in the LCD window.
2. There are no helps for the Maintenance mode. Follow parameter change procedures to the letter.
Changing Baud Rate from Automatic to 9600:
1. Enter 10 (one, zero). This will bring up WSW00 on the LCD window.
2. Change the 00 to 19. If the baud rate is set to automatic, the numbers that appear will be 11100010.
3. Change the 11100010 to 01100010. This sets the baud rate to 9600.
4. Press the "Set" button just below the LCD window.
5. Press "Stop".
6. Enter 99. This will exit Maintenance mode and make the fax ready to use again.
Feb 15, 2011 | Brother IntelliFax-4100e Fax
Change baud rate on panafax uf880,885
That won't make any difference. ALL fax machines are ANALOG and won't work on a DIGITAL phone lines reliably
Nov 17, 2009 | Office Equipment & Supplies
Need the baud rate to be 9600
fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
Dec 03, 2008 | Brother IntelliFAX 2800 Laser Fax
Change baud rate
Baud Rate is to lower the transmission speed of the fax, however these are the temp settings and once the power is off you have to reconfigure that. Follow the following steps :
From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
    1. Enter the parameter ____ on the key board and press the Check Mark.
    1. 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    1. The screen will read Cfg param val: 26
    1. Enter in the value ____ and then press the Check Mark .
    1. 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    1. Screen will read Test -001+
    2. Press the Reset button until you get back to Ready
    Dec 13, 2007 | HP OfficeJet D135 All-In-One InkJet...
    HP PSC 950 All-In-One InkJet Printer Logo
    143 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
