Question about Maytag Atlantis MAV9501E Top Load Washer
Hi, Our Maytag washer (model MAV9501EWW) is leaking. Could you tell me how to remove the front panel ?
    President:
  • 3,773 Answers
Remove the two screws at bottom of front panel and
pull panel out from the bottom.
Posted on Sep 12, 2010
I need to remove panel to access inside of Maytag washer model A207... how do i get in there?
insert a putty knife from the front into the bottom of the top lid panel between the lid panel and the front panel about two inches from both sides of the washer push the putty knife in firmly; this will release the hidden clips that hold the washer's top on and, allow you to lift off the top of the washer
Feb 04, 2013 | Washing Machines
My maytag epic z is leaking from underneath
Remove the front bottom panel. Should be three 1/4" screws on bottom lip of panel. See if you can tell where leak originated. Chances are good you just need to pop the cap off the drain pump and clean it out. Here is a vid that explains the procedure.
http://www.youtube.com/watch?v=iLftnaruKp8
Jan 21, 2013 | Maytag EPIC MFW9700S Front Load Washer
Sudsy water is leaking from the machine
Hello there and thank you for choosing fixya
The tub seal is the most common thing that causes Maytag washers to leak. This is unfortunate because the tub seal is an expensive repair job and not one I would suggest doing yourself. I say this because it is complicated and requires special tools to perform this job. To check if the tub seal is bad, first remove the front panel by removing the two screws from the bottom of the front panel. If you have a newer model, prize the bottom clips with a screwdriver. Then pull the bottom of the panel until the top clips release. Then start the washer and watch for a leak around transmission where it goes through the tub. If it does leak then the tub seal is bad and needs replacing. If you have the tool or willing to buy it click here for instructions on how to replace the tub seal. If the tub seal doesn't, leak you probably found the leak while performing this test.
Mar 07, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Washer leaks after it starts to agitate. It seems to be coming from the front of the washer. Thanks for any help.
To find where the leak is coming from, remove the 2 bottom bolts on the lower kick panel and remove panel. Next, remove the 2 bolts holding the upper front panel and remove it also. Now, with the front panels removed, run the washer and look for where it is leaking from. Repost your observations.
Feb 11, 2011 | Maytag SAV365ZAWW 3.3 cu.ft.
Model MAV9501EWW not spinning but it is pumping
Hello & Welcome to FixYa
When the washer is not spinning however, pump out the water then the problem is with the lid switch that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 13, 2011 | Maytag Atlantis MAV9501E Top Load Washer
LAT 7793 ABL model number. Washer leaking during fill...? a seal or gasket but not sure how to remove the spin bars to access it
On Your washer to locate a leak, remove the front panel first. Should be two clips at the bottom of front panel, use a putty knife to pry them down while pulling lower of front panel forward (older models used two screws right through front panel on left and right sides). After getting both lower clips loose, pull bottom of front panel forward to remove from top.
Set front panel aside and then use a 3/8" socket or nut-driver to remove two screws (one each) in the front right and left corners that secure the top to the side panels of the washer (inside in front corners going upwards). After screws are removed slide machine away from the wall about 8-10" and lift front of top up. Will pivot up like the hood on a car. This will allow you to examine machine for leaks.
Let me know when you come up with leak location if you need any more help!!
Jun 30, 2010 | Maytag LAT3600A Top Load Washer
Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
May 30, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Stackable maytag washer and dryer
Hello, on most Maytag units you can take the the front panel off by removing 2 phillips screws , 1 on each side of the front panel. With the panel off you can run the machine and see where the water is coming from. Good luck
Dec 21, 2008 | Maytag LSE7806A Top Load Stacked...
Problems with MAV9501EWW Washing Machine :(
your seals and bearings are bad do you wash a lot of sandy gritty clothes if you do that is the cause of the problem
Jan 19, 2008 | Maytag Atlantis MAV9501E Top Load Washer
Maytag Atlantis MAV9501E Top Load Washer Logo
323 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
