Question about Nintendo DSi Black Console
My volume button on my dsi is stuck on volume down. how ca i fix it
The volume button keeps going continuously up and down on it's own. How can this be fixed?
Sounds like your volume button(s) are stuck in the pushed-in position.
If you have some sort of a protective case on your device, make sure it's the correct one and that it doesn't push the volume button(s) in on its own.
If you don't have a case make sure the volume button(s) aren't gummed up with some sticky substance so they are stuck down.
If none of the above applies you could have a hardware (electrical) problem inside your device with the volume button switches.
May 12, 2015 | Tablets & eReaders
Samsung le40b530
Chances are that one of the volume buttons (either on the TV itself or on the remote) is stuck. You'll be able to know if it's the remote by taking out its batteries and trying the same process. If the issue persists, see if the volume down button on the TV is stuck and can be freed.
Dec 18, 2013 | RCA Audio Players & Recorders
Hi, could you help me please? recently my stupid nephew tried connecting the internet to his dsi and then he switched the dsi off, when he tried to switch the dsi ON it said: "an error has occurred...
Close the DS, turn the volume all the way down and then press a few more times, reopen, hold down power switch. It should turn off.
If it still doesn't work then it look like it was trying to do an update and was shut off while updating.
For a Guarantee fix you must change your DSi motherboard, they cost around $40 on ebay.
Thanks
www.1RepairStop.com
We Fix Everything
Sep 03, 2011 | Dsi Video Game Consoles & Games
My volume is stuck on high nothing is stuck in buttons
Call Nintendo Tech support, and send it in for repair.
Aug 16, 2011 | Nintendo DSi Black Console
Every time I try to play a game the screens goes black and it says; an error has occurred. Press and hold the Power Button to turn the system off. Please see the Nintendo DSi Operations Manual for help...
Every time I try to play a game the screens goes black and it says; an error has occurred. Press and hold the Power Button to turn the system off. Please see the Nintendo DSi Operations Manual for help troubleshooting. But I don't have the manual, ca anyone help me please.Thank you!
May 12, 2010 | Nintendo DSi Black Console
Main screen frozen
what ever you do dont listen to him there is a solution mine was stuck white screen and would not turn off and i was so close to doing what he said but now here is the solution
Step one:unplug dsi (if it is charging)
step two:close the dsi
step three:once it is closed turn volume down all the way witout opening
step four:set the dsi in front of a fan vent or someplace it will get a breeze
step five:open the dsi and hold power switch for like 6 to 10 seconds
(even when it turns off keep holding it for a couple more seconds)
now you an plug it back in and turn it on and VAWALä
hope this helped:)
Jan 08, 2010 | Nintendo DSi White Console
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
Nintendo dsi screens keep freezing and will not turn off
hope this helped:)
Apr 12, 2009 | Nintendo DSi White Console
Black DSi frozen.
Everyone i just found out how to fix a black or white dsi that is frozen and wont turn off!!
hope this helped:)
Jan 02, 2009 | Nintendo DSi White Console
Nintendo DSi Black Console Logo
197 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
