Question about Microsoft Xbox 360 Console
X-Box 360 3 red lights of doom. How do I fix it?
  • Rod Sims
    Rod Sims Sep 13, 2010
    That depends on weather you believe you are able
    to flow simple instructions , and have the tools and focus to
    complete the job?
  • Rod Sims
    Have you take your system apart yet? Rob
  • 51 Answers
Hi there b1sott
What to do when your xbox Has problems with flashing red lights RROD/red rings of death.
You will need some simple repairs done on your XBOX as the GPU chip (Graphics) or the CPU chip (brain) or even both have lost connection to the motherboard Due to overheating.
Option 1
You can send this off to Microsoft if your still in warranty because it is included in there free fixes so they will do the collecting for you, fix it and return the Xbox to you, all for free, but it will take 4-6 weeks.
Option 2
If you are out of warranty its the same process as above but its $150 in cost
Option 3
What I recommend is a XBOX REPAIR GUIDE that will show you the simple steps yourself, you will be up and running again in less than an hour and the cost is far less than option 2 & 3
Feel Free to leave me a comment if you need further assistance.
Posted on Jun 22, 2011
5 Suggested Answers
SOURCE: 3 red lights
it means you have a lose wire
Posted on Jan 04, 2009
SOURCE: red ring of light in x box 360
send it to mee Ill fix it for you
Posted on May 24, 2009
  • 59 Answers
SOURCE: x box 360 1 red light e74
This indicates overheating and could lead to terminal problems in the console... I would send it to MS for repair... also see this link if you like....
http://ezinearticles.com/?Xbox-360-E74-Error---Everything-You-Wanted-to-Know-About-Error-E74&id=2613185
Posted on Jul 28, 2009
SOURCE: My xbox 360 has the
E71 can be a result of a few things. The most common way to rid the problem is to change the output settings briefly (If your playing HD switch to SD cables or vice versa). I know that has fixed many peoples E71. If not, you may have to reformat your HDD to factory settings (Make a backup of your game saves first!)
Posted on Mar 14, 2011
My 360 goes off and shoes #1 & #3 turn red and started blenking
Your Xbox 360 has the RLOD also known as the "Red Light of Death".
If your warranty is still valid, you can send your Xbox 360 to Microsoft & they will fix it without charge. If not, there are solutions on how to do it yourself, and if that still doesn't work out for you, take your 360 in to Best Buy and they will help you out for a fee.
Jul 30, 2010 | Microsoft Xbox 360 Console
XBox 360 does not work. Red ring around the start button.
You have what is called the "red ring of death." This was a huge problem with the 360 when they first came out. Essentially, your box overheated and died. If it is still under warranty, you can call support and tell them what the problem is and they will most likely replace it. Otherwise, it's time for a new box. Sorry
Jul 19, 2010 | Microsoft Xbox 360 Console
Red ring
hi there,
your xbox 360 need service open it and remove all dust around the fan and prosseser every thing fine again.
Jul 11, 2010 | Microsoft Xbox 360 Console
Locks up and has three red flashing lights where the controler lights are.
3 red lights on the Xbox 360 is the most common error and it means "General Hardware failure. To fix this you need to stop the amount of heat that the GPU and the CPU is taking.
To do this you can use the recommended guide that has been on the market for 3 years or you can send it in.
As long as you use a good guide you will easily be able to fix the red lights of doom.
Feb 09, 2010 | Microsoft Xbox 360 Console
Red ring flashing
Red lights is normally the red light of doom, you will need to send it in to get it fixed or you can fix it yourself using a good guide to fix it and stop the heat build up.
Dec 26, 2009 | Microsoft Xbox 360 Console
My xbox 360 has three red lights running round the front circle it is nearly one year old
This is due to the infamous over heating issue. go on E-bay and search for Red Light of Doom. There a lot of people who do fixes for this and I had mine fixed for $25 plus shipping. Once its fixed it stays fixed.
Nov 04, 2009 | Microsoft Xbox 360 Console
3 red lights on ring what is the poblem
AAAAAAAAGGGGGGGHHHHHH!!!!!!!!!!
Thats is known as the Red Ring Of Death! (RRD or RROD)
If this happens 3 times you MUST send your x-box into microsoft so they can fix it.
Oct 18, 2009 | Microsoft Xbox 360 Console
Red ring of death
1-800-4MY-XBOX
Have Microsoft fix it for you.
If you want to try to fix it yourself, http://xbox-experts.com/ and check the forums.
Oct 10, 2009 | Microsoft Xbox 360 Console
Red lights
the red lights of doom, means hardware failure
go here
http://support.microsoft.com/kb/907534
May 12, 2008 | Microsoft Xbox 360 Console
Xbox 360 games
and if you do try to fix it yourself, or you've voided the warranty ( by already opening it) make sure you DON"T do the " towel Fix " it will only make things worse. you need to do an X Clamp repair. It's simple. I had no experiance whatsoever.with electronics. and I was able to figure it out the first time I tried it. I did it three weeks ago and my X box is quieter than ever and it works fine. so serach on you tube " X Box 360 X clamp fix " and you should see what you need to fix your problem.
Aug 12, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
44 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
