Question about Whirlpool Microwave Ovens
Putting wall bracing up before sheetrock. What is the width of the wall brace for the microhood and how far below the upper cabinet should it be installed?
  • 490 Answers
Howdy, when you have a situation where all the specs are not well defined, it is a fair cheat to use 1/2 to 3/4 inch plywood as a backer,covering the largest possible dimention of the installed machine. I have simply cut it to fit the stud spaces and make sure my wires and pipes are all clear. Kitchen is the best room in the house, I think. Good job making sure you have your bases covered.
regards, Farmerbear at FixYa.com
Posted on Sep 13, 2010
How do i remove an old oven
It is much easier for two people to remove the microhood. If attempting alone, please move the range out so you can get under the micro to support the weight. If the range stays in place, protect the top from damage.
1. make a landing site to the side, to protect the floor when putting the micro down after removal.
2. Disconnect the power cord in the cabinet above.
3. loosen the two screws in the bottom front corners of the cabinet above. When removed the front of the micro will drop, be ready for the weight. Busy times, tools in hands microwave coming down in front.
4. tilt the front down. pull the cord out of the upper cabinet.
5. with micro still tilted down in front, lift the back of the unit upward to free it from the wall plate.
6. remove the fasteners in the wall plate and remove.
Congrats, begin celebration.
Jul 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How far out does a microhood sit from the cabinet. My cabinets are 12 inches and the microhood I want is 16 deep. Also it will be 19 inches above my stove.
Don't know right off the top of my head, but the installation instructions should tell the min and max height from the stove. If they don't you may want to contact an electrician to find out.
Mar 29, 2010 | Kenmore 62622 Microwave Oven
How do I remove my Hotpoint microwave RVM 44004? Two bolts visible from the cabinet down into the microwave. Removed them with zero result. No other fasteners visible in top or side cabinets.
1. make a landing site to the side to protect the floor when putting the micro down after removal.
Jan 20, 2010 | Hotpoint RVM1435 Microwave Oven
How do you un-install a kenmore 665.61639100 microwave?
the link below will take you to the installation instructions if needed.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0211226.pdf
Dec 26, 2009 | Kenmore 62642 / 62644 / 62649 Microwave...
I want to remove/replace a 2000 GE JVM1640WB microwave and don't know how to access the mounting/securing screws to allow me to remove the old unit. Are they behind the top grill, which looks like it's...
I have found and provided a link installation instructions for your existing model. The front is held in place by two screws through the cabinet above into the top of the micro and the back is supported by a wall bracket. A new microhood will fit into the space, but will install a little differently. link to instructions:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003675895.PDF
Dec 25, 2009 | Microwave Ovens
I bought a used over the range microwave oven( kenmore) I would like to know how to install it knowing there is an opening to the roof. thank you
Most Kenmore microhoods use a 3" by 10" exhaust duct. Check for correct demensions. Make sure that the existing vent is this size or that you have room to adapt to this size. There should be a damper mounted to the top of the micro which will attach to the vent duct work. You will need an outlet in the cabinet above the micohood. This should be on a circuit of it's own. The microhood should have a wall plate for the back wall. I'm going to assume there are no templates available. Hold the wall plate against the back of the micro to determine the height placement in the opening. Most install centered under and against the cabinet above. Not all do, so this will confirm. Mount the wall plate to the existing wall studs with at least 1/4" by 2-1/2" lag bolts. Bore an 1-1/4" hole in the right rear corner of the cabinet above, about 2" out from the back of the cabinet and 2" in from the side, this is not a critical measurement, it is to pass the electric cord into the upper cabinet. There are two screws that support the front of the hood. I believe they are 1/4" by 3-1/2" long. If not included, check for size. The hardwae will have them, get flat washers to fit both also. Measure from the back of the micro to the mounting holes in the top of the micro, include the wall plate in this measurement, they'll be about 10" out from the back and about 1-1/2" in from the edge, near the front, but check that measurement, they vary. Drill 3/8" holes in the bottom of the cabinet at these locations. If doing this alone, best that you move the range out. It's nice to have a helper at lifting time. With the plate on the wall and the holes in the bottom of the cabinet, your ready. Put the 1/4" screws and someting to drive them in the upper cabinet, so they'll be available. Lift the micro into the opening with the front tilted downward, hook the back of it into the bottom of the wall plate, push the cord into the upper cabinet, tilt the front of the micro up until you can start the front support screws. Start both, don't let go of the micro until you are sure that both screws are started and will support the front weight. Once you're sure, tighten both screws all the way and connect the vent. Steel tape is best for sealing up any leaks. Power up the outlet, plug in the microhood and put in the popcorn. Get a good movie and enjoy in your accomplishment. Congrats. PS: Make sure the roof vent opens when the hood is turned on, I have seen them stuck shut from grease build-up.
Oct 22, 2009 | Microwave Ovens
Who makes a microwave oven that mounts in an
Why can't you use the wall plate? Even if you had to use construction adhesive it would be better than nothing. If you are installing in an island setting then you will have to reinforce the cabinets as they would have to support the weight of the micro.
Eric
Oct 01, 2009 | Microwave Ovens
I need to know how to uninstall a GE spacemaker microwave oven model JVM250av001...any one out there know how..?
Put padding on the floor near by for a landing zone. Disconnect the power in the cabinet above. There are two screws in the upper cabinet that support the front. There is a wall plate that supports the back. When the two front screws are removed you will need to be supporting the microhood or it will fall. A strong assistant is nice to have. I like to have the stove out of the way so I can get under the microwave to support it. Once the front two screws are removed, tip the front down, pull the cord out of the upper cabinet. Then lift the back slightly to remove it from the channel on the wall bracket. Set it down Done.
Sep 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Presently have a regular hood, would like a microhood. How many inches clearance do I need between the top of the stove to the bottom of the cabinet?
This is a good question to ask at the point of sale. The measurement varies for different models and makes, but 33 - 36 inches is ideal. If you have a 12 or 15 inch tall cabinet above the stove, you are fine. A microhood does require a dedicated electrical circuit. When powewring off the current hood circuit, check to see if any other lights or outlets go off.
Jul 07, 2009 | Microwave Ovens
Microwave installation
I'm a kitchen remodeler, and I've seen this problem with Kenmores (so it probably exists with some other brands too. The ones I have seen have the typical bolts through the top, but there's more. The flat mounting plate on the wall has an protruding piece that fits well into the body of the microwave when the unit is slid into place. It has a threaded hole in the end of the extension, and the sheet metal screw or bolt that goes into this is causing your anguish. To access this, you must remove the top front louvers (maybe some other trim plates as well). You'll eventually find the bolt that unscrews with a horizontal screwdriver. Chris Harrison, Richmond Refacing.
Sep 23, 2007 | Microwave Ovens
Microwave Ovens Logo
51 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
