Question about Kodak Easyshare V1233 12.1MP Digital Camera with 3x Optical Zoom
My lense will not come out. It's stuck and the camera is unusable.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with try to blow compressed air around the lens cover so that if there is any dirt it cleans if off. You can also stick a thin strip of paper between the lens shutter and the outer support ring & move it in a way that it clears the debris that’s stuck in there. If still the issue is not resolved then you’ll have to replace the lens assembly & lens mechanism to fix this issue. It is recommended to be done by a professional. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
My samsung s830 digital camera,while switch on the lens is not coming out fully....it come little forward and getting stuck.then automatically it is getting switched off...what is the problem and how can i...
Chech wether something is not stuck between yopur lenses of camera.....it is dfue to...that something is stoping the lenses to come out...there might be something betwwen lense and camera walls...check it out..
Oct 24, 2010 | Samsung S830 Digital Camera
Lense stuck out camera shuts downwith lense out
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Apr 21, 2010 | Kodak EASYSHARE M1063 Digital Camera
Lense was stuck out did what toothy said now the lense is stuck i
Hi!
Please follow the troubleshooting given below to resolve the issue:
(a) Turn off the Camera and remove the Battery then press and hold the power button for 30 seconds.
(b) Then, reinsert the Battery and turn the Camera ON. Please make sure that the Battery is fully charged.
(c) Next, press and hold the Reset button for 30 seconds located above the DC-in jack on the Camera using a sharp pointed object.
If the Camera doesn't operate normally even after performing all the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
CAMERA DROPPED AND LENSE IS STUCK OUT AND CAMERA
your len's mechanism is damaged or jammed. It would be too expensive to repair!!Hopefully this helps
Jul 24, 2009 | Polaroid i631 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Lense of camera is stuck out
Defective Lens Block
Needs to be replaced.
Jan 12, 2009 | Canon PowerShot SD870 IS Digital Camera
My camera's display is black when I try to take a picture, and all the pictures I take are all black. How do I fix this problem?
Your digital signal processor is bad or your lense shutter is stuck on the inside. A stuck lense can be fixed by replacing the lense barrel. Check out Camera Shy Anna on Ebay stores. They can fix your digital camera.
Nov 25, 2008 | Cameras
Camera lense/power
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 18, 2008 | Canon PowerShot A510 Digital Camera
Kodak Easyshare V1233 12.1MP Digital Camera with 3x Optical Zoom Logo
35 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
