Question about Canon PowerShot S1 IS Digital Camera
Excessive frost- maybe door won't close well Builds up on to shelves the worst--could it be the rubber seal
    Brigadier General:
  • 3,006 Answers
First you must fully defrost your freezer. Frost simply attracts more frost. A build up of frost large enough to prevent the door closing properly will grow very rapidly indeed and waste a lot of electricity; it will also overload the compressor and can cause it to fail prematurely.
If the seal is damaged then it will allow moist air in and cause frost. If the seal has simply become unseated, then refitting it will prevent a recurrence.
Unless you have a frost-free model, then all freezers eventually need defrosting. You can slow the process by never opening the freezer door unnecessarily and also by never leaving it open any longer than necessary. Frost free models rely on air circulation via a fan to prevent frost build up. If the fan fails, or if the freezer is overloaded and so preventing air circulation then it will still frost up.
Please take a brief moment to rate my answer.
Posted on Sep 12, 2010
Freezer door won't close tightly and frost builds up
This is quite often caused by several factors ...
1] Worn door seals [REPLACE them] ...
2] Rusted door PINS [in older units] and/or worn PLASTIC BUSHES that support these pins [REPAIR or REPLACE them] ...
3] MISALIGNED and/or WARPED door [mostly in older units and/or if the kids hang off the door (especially young children) over an extended time ...
MOST doors are easily removed [but some are quite heavy and/or have electrical wiring/water lines etc. inside] so be careful. Usually you will need to remove the TOP hinge [screws usually under cover-plate] and then gently raise and lift-off the door from its bottom hinge pin. If you lift up the rubber door seal edge you will usually find a series of screws underneath. Just undo these to remove the inner shelf/door lining to replace the door seals. You can buy ready-made replacement seals from most major manufacturers and DIY ... or you can get a tradesman to do this for you [companies such as "SEAL A FRIDGE" can be found in your local phone directory or on-line] ...
Sep 21, 2014 | Refrigerators
Is your service free of charge? if yes what cause smowy ice around the freezer door in a refidgerator
This is caused by excess room air getting into the freezer because of leaky door gasket which should seal snugly on a dollar bill inserted between the gasket. Frequent or prolonged door opening will also allow room air in. The higher moisture content in the air freezes on the surfaces of the food etc.
Mar 12, 2011 | Refrigerators
LG french door refrigerator, model # FRFD22850TT, light stayed on and food was hot. Hoe do we get the light repaired? Also, frost builds up on Rt. side of freezer even with the door always closed, no...
the door switch control the light. check the switch
defrost thermostat and heat element control frost, check all of them
if u live near madison . wi , i charge u $100 fix the problem . part may be $100
Jan 13, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
We have a 2004 maytag upright freezer and the shelves frost up and food has freezer burn within days. We have it set at max setting and it is -5 degrees. The numbers on the freezer are SN 10095657EA; MN...
in looking up your model mqu1554aew. i cked the wiring and this is a plane jane freezer it is not frost free and running the temp at 5 deg is a good tempt for the freezer . now you stated that the shelves frost up rght a -way . so i would think that the door seal is not sealing . and the compressor is running 24 /7 . it should get cold and shut off and run times should be at 45 to 50 % .. so take a dollar and close it in the seal in different places and ck the tennsion if low or none its leaking . also look for the door and should be square to the cabnet . and also level . hope this helps mm feed back pls .
Dec 11, 2010 | Refrigerators
FROST BUILDS UP IN ICE CHUTE FROM STORAGE BIN, AND BUILD-UP BLOCKS RELEASE OF CUBES....ALSO WATER LEAKAGE OUTSIDE LIKE WARM AIR IS COMING UP FROM OUTSIDE...
As a suggestion:
Check the trap door that opens and closes each time you obtain ice cubes. The water leakage may indicate a damaged seal allowing air from outside to enter. This will cause increased frosting and blockage.
The trap door may not be closing all the way or the magnetic seal around the freezer door may be damaged or not sealing completely.
You may also need to check the thermostat.
Temperature may be set too low. If you make an adjustment allow the unit to stabilize for 12 hours before attempting another change.
Oct 04, 2009 | GE Refrigerators
Freezer side builds up ice on back wall ,then both sides stop air flow
Hmm excessive moisture entering the unit - this can happen with excessive door openings or bad seal gaskets - make sure the seal is tight and not worn out. You are talking about frosting on the freezer outer wall right not behind the back panel ?
Try removing the back panel and look for icing/overfrost on the evap coils too - that could signal a defrost problem inw hich case you would need to inspect and change the control board or defrost timer components.
Sep 26, 2009 | Kenmore 53642 / 53644 Side by Side...
I HAVE AN UPRIGHT FREEZER THAT IS DEVELOPING FROST ON ALL THE SHELVES, I DEFROSTED IT TODAY AND RIGHT AWAY THE SHELVES DEVELOPED FROST AGAIN. THIS HAS NEVER HAPPENED BEFORE, IT WOULD GET FROST ON THE...
Sounds like an air leak. Check the door gasket. If that is sealing well all the way around, try putting a peice of foil duct tape over the two small vents in the bottom of the door.
Sep 05, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
SubZero 690: Frost builds up on ice chute flapper door
you have a bad seal, Take a dollar bill and slide it in between the door seal and the frig. slide it up and down to see if if has drag on it. If you find places it dont touch loosen the screws and adjust the hinges till it fits tight. In some cases you might have to tweak the doors if they need it.
Aug 11, 2009 | Sub-Zero 690 Side by Side Refrigerator
Frost in Freezer, front of shelves
Sometimes enough ice will accumulate at the front of the shelves to actually block the door from closing completely. Are you in and out of the freezer often? Moist air that hits the frozen shelf surface will accumulate at the front of the shelves first because that's where it hits first. Check that the freezer is level and plumb not on a "twist". If it is sometimes the door will not seat properly and therefore leave a gap for air to get in. Take a dollar bill and place it in the door seal surface. Close the door and try to slide the bill out from between the door frame and the seal. Do this in several places around the door. If it comes out with little or no friction you may have found your problem. Finally, completely defrost the freezer shelves after removing all the food. Don't poke or dig with an ice pick or screwdriver or you will poke a hole in the tubes and ruin the freezer. You can speed things up with some hot water in a pan placed inside the freezer. Be ready with towels or pans to collect water. Good luck!
Jun 26, 2009 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Canon PowerShot S1 IS Digital Camera Logo
149 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
