Question about Black & Decker Hammering
Adding breakers to a main box where there is no more space is there an add on that you can install?
  • 377 Answers
If the breaker box is fairly new, most manufacturers have "slim breakers" that allow for a double breaker to be put in the same space as a full size breaker. There should be no change in performance or safety. Can usually find them at Home Depot or Lowes, etc.
Posted on Sep 12, 2010
  • pwillitz Sep 17, 2010
    THANK YOU VERY MUCH FOR THE RATING YOU GAVE ME!!!
    I greatly appreciate it and I am happy I was able to assist you.
Breakers for T40004R
Copy following link for Intermatic control center resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#base
Use any flat blade circuit breaker like Siemens.
T40004R has breaker base has 8 breaker spaces, maximum 125 amps, with #1 wire from main breaker box.
http://waterheatertimer.org/Color-codewire.html
Add a comment
Jul 02, 2013 | Intermatic Hardware & Accessories
Electical panel
1) Add a subpanel using extra breaker space:
http://waterheatertimer.org/How-to-install-a-subpanel.html
2) Choose correct wire and breaker.
Increase to next larger size for distances over 100 feet from breaker.
3) Calculate total load on main breaker to make sure service panel is large enough for amp draw:
http://waterheatertimer.org/Troubleshoot-household-electricity.html#stress
4) Add a comment
Feb 11, 2013 | Electrical Supplies
I needed to add another light fixture and mount the switch next to an existing switch to another light fixture. When i run the hot wire from the existing switch to my new switch for the positive and t
You can use a double switch, or make a '2-gang box' by adding another switch.
Copy following links for wiring multiple switches inside same box, and wiring double switch.
http://waterheatertimer.org/How-to-wire-switches.html#double
http://waterheatertimer.org/How-to-wire-switches.html#gang
Here is image showing 120Volt wiring inside main breaker box, so Hot Neutral and ground are clearer.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-8-8.jpg
Aug 23, 2012 | Home
I have a 125 FPE box currently the combined total of all breakers presently in the box is 190 amps. I am wanting to replace a single pole 20 with a single pole 40. Am I already maxed out or do I have room...
You can add the breaker.
The key is total electric use.
As long as total consumption does not exceed amps shown on main breaker, then the new 40A breaker installation is ok.
If total consumption exceeds main breaker, then the main breaker will start to get hot and then trip.
Put hand on main breaker and feel for warmth.
The main should not feel warm.
Consider upgrading to 150A or 200A service.
Aug 22, 2011 | Connecticut Electric UBIF040N FPE...
Plastic clips that hold breaker in broke off
1) If this is for main breaker, then replacement is only option.
2) If this is for 120V or 240V breaker, then move breakers around so you can make space by adding tandem breaker(s) if available.
http://waterheatertimer.org/images/Circuit-Breakers-ap235-500.jpg
3) You can also make space by doubling lesser used circuit onto one breaker, making sure that 14 gauge wire goes on size 15A breaker and 12 gauge wire goes on 20A breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/Color-codewire2.html
4) You can work around by adding adding subpanel
Mar 02, 2011 | General Electric GE INDUSTRIAL SYSTEMS...
1 question can Cutler Hammer breakers have the amperage feed through the breakers. To the breaker box and from the box grid to the load. Does it matter which way the amperage is fed through the breaker?...
There seem to be several questions mingled in with those 2 questions.
1) Amps can go either way
2) Breakers trip when heat exceeds certain level. Heat is caused by amps.
3) You want to add a subpanel in garage.
I do not know the code in your area for installing a subpanel.
Your plan will work by connecting 6 gauge wire to main breaker, and new 60 amp breaker will protect wires between main box and subpanel.
Remember, wires going into main breaker cannot be turned off without pulling meter.
Some areas require license to pull meter.
4) To work around license and meter-pull, simply replace a 240V breaker in main panel with your new 60 amp breaker.
Then move breakers around to match new set-up.
New subpanel can accommodate two new 240V breakers and one new 120 Breaker
5) 6 gauge wire is correct for 60 amp breaker.
6) I'm not sure what you mean by the box rails?
7) Do you need more amperage on main service?
This means adding a larger service panel with 150 Watt or 200 Watt main breaker.
Some areas require service upgrade when remodeling or adding circuits.
8) How to figure total amp draw at your house.
Add up total watts being used.
For example you have 1/2 Hp motor
754 watts per Hp
1/2 Hp = 377Watts
Volts x Amps = Watts
Amps = Watts divided by Volts.
377 Watts divided by 240Volts = 1.57 amps (plus a bit more amperage when motor starts)
40 watt light bulb divided by 120Volts = .33 amps
Double oven has label located inside door that shows upper and lower wattage.
Dishwasher, dryer, big screen TV, satellite receiver all have labels that show wattage.
Water heater has label that shows wattage of each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more help
Feb 18, 2011 | Cutler Hammer 100 Amp Main Breaker...
Major cirsuit breaker blew and partial loss of power in residential home ...is bus port still good? Looks good. replaced breaker and working again..will this last?
1) If busbar looks good it probably is good.
Usually when bus is bad, it has burned appearance, and looks like it is ready to crumble or is crumbling.
2) Problem with bad busbar, we sometimes add subpanel next to main box.
Buy subpanel box Home center or electric supply.
Square-D subpanel shown on following page came from electric supply.
3) You can also add tandem breaker to main box.
Tandem breaker fits over one bus finger, but is actually two separate breakers.
Then double-up two lightly used circuits so you have room to move breakers around.
See image showing tandem.
http://waterheatertimer.org/images/ap-235-breakers.jpg
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 16, 2011 | Electric General Ted134050 50a 480v...
Main breaker is kicking out
Please call an electrician. There are 3 possibilities---- 1. The sum of the branches are occasionally spiking higher than 200 amps. (If you add up all of the branch ratings you will find that their combined capacity is much higher than 200 Amps in total) In this case you need to find a way to level the load or add capacity by adding a second breaker box -- you can't do this yourself because you need help from the utility company. 2. There is something shorting out inside your breaker box. (unlikely) 3. There is a problem with the main and you need to replace it. But DO NOT ATTEMPT TO DO THIS YOURSELF. In all three cases you need help from an electrician.
Jun 18, 2010 | Cutler Hammer Eaton Electical #BD3030...
Blown breaker
It sound like all of those go through your bathroom GFCI. I would recommend moving your outdoor circuit breaker indoors if possible or enclosing it to make it water-proof. You may also do some rewiring from your main breaker box ( if you are handy) to eliminate the outdoor box completely considering you have 100 amp / 200 amp breaker box inside your house. If you still have an old FUSE BOX with 60 amp service, I would recommend replacing it with a 100 amp or 200 amp breaker box depending on the size of your house. I would separate the laundry room by itself with 12/2 gauge wire with ground on a 20 amp breaker. You can then take your bathroom (using 12/2 gauge wire with ground keeping your gfci ) and run it to another breaker in the house with a 20 amp breaker or add a new one if there is room in your main box. Now all you have left is the porch light. You can run that separate from everything to your main breaker box using 14/2 gauge with ground to a breaker in your main box by adding a new 15 amp breaker or adding it to another 15 amp breaker that does not have a very high load such as a bedroom. In general Kitchens, Bathrooms, Laundry rooms should be on there own separate 20 amp breakers. Most every other room can be 14/2 with ground on a 15 amp breaker... hope this helps....Joe
Dec 17, 2008 | Prime 10 Amp Circuit Breaker
Hammering Logo
80 people viewed this question
Top Black & Decker Hammering Experts
Gary Nitowski
Piyal Perera
Piyal Perera
Are you a Black & Decker Hammering Expert? Answer questions, earn points and help others
