Question about Jenn-Air JFC2087HRS Side by Side Refrigerator
Water doesn't flow from water dispenser ice maker is not making ice seems like it's not getting water should I pull the fridge out to check the water supply line? I'm worried about damaging it in the process thanks!
    President:
  • 3,773 Answers
The water valve underneath in back of ref needs replacing.
Its the thing that the water line from the wall hooks to.
Also check Water pressure when change it.
You will have to pull it out to get to the valve.
Posted on Sep 13, 2010
  • Leo Ponder
    Leo Ponder Sep 13, 2010
    Go to your local appliance parts store with your model number
    and they will instruct you how to change it.
Where do I find the ice maker inlet water valve or solenoid? The valve on the back of my fridge has only one hose going to both the water dispenser and ice maker and the water dispenser works fine.
Since there is water that flows to the water dispenser, the water valve is working. Now, there's a spout that water flows from to the icemaker tray. Look for it. It's located on the back wall inside the freezer and maybe behind the icemaker tray. Check and see if it's frozen. If so, defrost your freezer by turning the temperature gauge to off position. Wait a while until it's defrosted, then turn it back on.
Next, make sure that the metal wire is in down position.
If that doesn't work, your icemaker maybe defective and needs replacement.
Nov 01, 2014 | Maytag MFI2665XEM Stainless Steel
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Stopped making ice
First of all is the water flowing into the ice-maker? Check the solenoid valve which regulates this water flow to the dispenser & ice maker. If water is flowing in, the ice-maker's thermostat may have malfunctioned, since this thermostat is separate from that inside the fridge...........sodeep
Aug 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice-maker problem
if the water runs constantly when you turn the water on its your valve but if it does it periodacally it probably your icemaker
Apr 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Side by side frigidaire ice maker not working
Check the water valve at the back of fridge. Are you getting water at the dispenser on the door? If so, the water valve may not be bad, but sometimes water will freeze in the tube that fills the icemaker. Pull it out from the back of the fridge and check it.Hope this helps !
Oct 08, 2017 | Frigidaire FRS26R4A Side by Side...
Fridge Freezer Ice maker problem
We have an Whirlpool side by side America fridge freezer. Water is not flowing into the ice-maker
Mar 31, 2008 | Refrigerators
Water dispenser
wow that's agood one!!!! theres a short for sure, just a matter of where. somehow your energizing both sides of water valve at once, sounds as if it would be behind the dispensor, at the switches. would remove the dispensor cover and have a look for a bad switch or exposed wire
Mar 08, 2008 | Refrigerators
Jenn-Air JFC2087HRS Side by Side Refrigerator Logo
63 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
