I have a linksys its about 5 years old and i dont have the cd to install what can i do to install it on the home computer
  • 2,229 Answers
If you have an operating system Windows XP or later, you don't need a CD to set up the router.
Posted on Sep 12, 2010
  • Art Ellison
    Art Ellison Sep 12, 2010
    I should have added something here:
    First plug the router in and push the red reset button on the back.
    Now plug your modem into the WAN port and your computer into one of the 4 LAN ports. Unplug everything. Now turn the modem on. Then turn the router on. Now turn your computer on. As long as there is no conflict between your modem and router for an IP address, you should be up and running.
I am installing linskys to my home computer. I follow al of the directions on the linkys cd but when i switch the wire from the modem to the router and plug it back into the tower i wil not have an...
I think you need an extra cat-5 wire.
1.
Plug one CAT-5 LAN cable into the port labeled WAN on Linksys then the other end into the cable Modem where your PC is normally
2.
now take a separate Cat-5 LAN cable adn plug it into port 1 on the linksys - the other end into your PC NIC
3.
Power cycle Cable Modem (remove battery), linksys, PC this will clear the MAC addresses
4.
turn on modem, linksys then pc
5.
loging to windows - open IE on address bar type 192.168.1.1 - this should be the default address of your router (unless you've changed your subnet) in which case I recommend you factory default the route and use default settings. after typing teh 192.1386.1.1 you should see the linksys login
6.
Now try yahoo.com in IE, the routers factory setting for DHCP should work fine without any end user programming from you.
please rate me, good luck
Aug 24, 2010 | Linksys Wireless-G Broadband Router
Can't get my adapter to connect...XP is stuck with Aquiring a network address.
Have had this same problem. This worked for me. Remove the adapter, uninstall linksys, if it is installed, restart the computer, insert the adapter, when found new hardware comes up, let windows use the install wizard to install the adapter. Sorry to say, i have used this method on 5 pcs and it failed on only one. Let's hope yours will also be possitive. Good luck.
May 04, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Ethernet port connection failure
You could get another ethernet card from ebay for less than $10. Although, honestly, I don't think the port could have oxidized in 5 years. What is the error message(s)?
Mar 29, 2009 | Linksys Wireless-G WRTP54G Router
I was given a linksys wireless-g model wrk54g router but it didn't come with an installation disk. I have a Thomson speedtouch modem ST530 V6. Right now I am hooked up thru ethernet and getting internet...
was the router used by previous users? or did you buy it? if it was used then it was probably configured for different ISP. You don't need any CD. Just connect to the router via your browser (probably http://192.168.1.1) and adjust settings in WAN section.
Mar 15, 2009 | Linksys Wireless-G Broadband Router
How to install linkys without the cd
You can manually install it even without a CD, if you dont know how to do that you can contact Linksys tech support so they can walk you through in configuring it manually , this is the number 800-3267114....
Hope that helps..........
Aug 25, 2008 | Linksys Wireless-G WRT54G Router
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Installing new memory
I would take it back to the Geek Squad.
If you want to fix it yourself, you need to get the drivers. Search your system for the driver file name it is looking for and then, point the installation wizard to that folder and let it load the drivers. Typically, drivers will be loaded in C:\Windows\System32
Jun 01, 2008 | Dell Dimension 2350 PC Desktop
Network adapter install drivers
These drivers are readily available at www.linksys.com Just look under Downloads, enter your model number and get the driver. You will probably need to burn it to a CD or Flash drive to install it on your computer.
Jun 05, 2007 | Linksys Network Adapter
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
