Question about Samsung DVD-HR734 DVD/HDD Recorder
My Samsung remote 00053H has stopped working, I have been told that it may be possible to reset it with a code. I have changed the batteries.
4 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: Hi, i have a split mural air condicioner Samsung
May be either your remote sensor or or receiving sensor in PCB weak. Find and replace.
Posted on Dec 08, 2010
  • 444 Answers
SOURCE: samsung ue46d6000 remote control stopped working
Get a new one,
Posted on Nov 03, 2012
gopakumarg43
  • 74383 Answers
SOURCE: Samsung LE32C450E1W TV remote control stopped working.
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Posted on Mar 24, 2013
How to reset a samsung AK-49 remote
If it is a universal remote control, you should have to set it up with the set-up codes to Samsung brand TVs.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 25, 2014 | Televison & Video
My samsung 3D led multisystem smart TV remote control does not work anymore
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Mar 24, 2013 | Samsung TV Remote Control
Samsung TV
Based on the information you described you may have a tuner
circuit problem or power intermitent faikure fron the power supply module.
Nov 02, 2012 | Samsung Televison & Video
Changed the batteries and it just stopped working ,I get nothing
If you have changed the batteries of the remote control, all setup codes previously it have, been resetted. You have to setup the remote to your TV, by it code, once again.
Jun 20, 2012 | Hitachi CLU-4324UG Remote Control
Android process acore stopped working , screen told me to force to close
Keep your battery charged to full
use the following code to reset(hard) your phone
*2767*3855# Hard Reset*
*#*#7780#*#* Factory Reset**
Feb 02, 2011 | Samsung Cell Phones
Remote control stopped working for Samsung DVD/VCR combo.
A quick and simple way to test and check if you have an output from the remote is to point it at your cellphone's camera and then to push any button, you should see a pulsing light on the display of your phones screen. If not then either the batteries you put in is also expired, or if the remote was standing for a long time with the old set of batteries in it you could have some corrosion on the contacts in the remote from leaking acid. Clean the contacts with fine grit sandpaper and try again.
If you get pulsing light then you need to program the remote again, if it is a programmable remote as it resets after approx 3 months once the batteries dies. A remote Make and model number would be helpfull in providing your with the correct sequence of programming.
Jul 31, 2009 | Televison & Video
My remote's batteries fell out & it stopped working.
Check and make sure that the batteries are getting full contact on each end...often when an electronic device falls and actually forces the batteries out on impact, the contact points are spread apart and prevents full contact on both ends of the battery(s). You can lightly bend the contacts in the remote just slightly... Just enough to get a full contact. If it has springs then assume that there is already full contact there. Secondly if you think you have full contact with the batteries then the next thing is that it may have some internal damage to the remote. (which can be ALOT of different problems) This is a simple solution possibility..Otherwise try a new set of batteries. If its still a no-go then it will require a replacement unless you know how to fix circuit boards.
Jul 07, 2009 | Televison & Video
Changed Batteries in garage door opener remote....now won't work
my suggestion would be to make sure that the codes to the opener match the remote and I would stop by a Sears service center for assistance or a Ace hardware store
Jan 21, 2009 | 2000 Oldsmobile Bravada
Samsung DVD-HR734 DVD/HDD Recorder Logo
285 people viewed this question
Henry  Thomas
Henry Thomas
