My computer is a6703w...worked fine on the 10th...turned it on on 9/11 says system boot failure...cannot detect cable device...everything is connected... is this an easy fix...or is it a virus
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 144 Answers
This should be a problem with the cable between monitor and CPU.
Posted on Sep 14, 2010
When I turn it on it says Realtek PCIe FE Family
i think the realtek PCIe controler is your video display controler
Oct 21, 2013 | Toshiba PSAY1U-012005 Satellite P755-S5260...
How can I a boot disk system failure on my Asus without a system disc?
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Nov 30, 2012 | Computers & Internet
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
The computer is having trouble finding the hard disk.
The problem could be a faulty hard disk or a faulty disk controller.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jan 27, 2012 | Computers & Internet
I have Acer 1200 Aspire. When I turn it on, it won't proceed past the initial window. It says boot failure.
It almost sounds like your primary boot disk is incorrectly selected in the BIOS. On older machines, the primary disk on the primary cable had to be the boot disk, but nowadays almost any device can be selected as boot disk. Check your BIOS setting and ensure that the hard disk partition that you have Windows installed on is selected as the first boot device. Otherwise, the system may be looking in the wrong place for the OS and giving the boot error.
Jan 07, 2012 | Acer Aspire X1200-B1601A PC Desktop
My laptop isnt working.as soon as u turn it on a black screen comes up and the message display says PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM!! how can i fix it
It goes to a network boot rather than booting straight to the HDD. restart your computer and press f2 immediatley. you are now on the BIOS page. check if your hard drive is detected and if not call Lenovo to have it replaced/repaired. if it is detected, after the PXE error, your computer should boot up just fine.
Jun 05, 2010 | Lenovo 3000 G530 Notebook
Dell Dimension E520 has "NO BOOT DEVICE AVAILABLE" message. Pressing F1 F2 doesn't help. What should I do?
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
Sep 03, 2009 | Dell Dimension 8400 PC Desktop
Problems with my inspiron 1501 details below
The problem your having could be the operating system is damange or the hard drive failed. Try to boot from a Windows XP or Vista CD to see if the drive is recognized.
Regards,
Sep 01, 2009 | Dell Inspiron 1501 Notebook
Boot failure
Most likely, your hard drive died. Enter the system BIOS to see what it is detecting (or not) for your hard drive(s). If the hard drive is not being detected as I suspect, you could just replace it and reinstall all of your software.
May 29, 2009 | Intel Pentium III , 900 MHz Processor
Disk boot failure
there are multiple reasons for this
1. hard drive failure
solution: replace hard drive reinstall operateing system
2. computer is not set to start from hard drive
solution: enter bios and set computer to start up from hard drive
3. Hard drive not detected or cable loose.
solution: check are the hard drive cables connected well. try disconnecting and then reconnecting.
4. Hard drive file system corrupted and unable to find start up files
solution: you can use the windows xp to enter repair console and try to correct the corruption with chkdsk command if that doesnt work you have to reinstall operateing system
Apr 04, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
