Question about HP Pavilion F1703 17" LCD Monitor
My monitor flashes that it recommends 1020x1080-60Hz but it doesn't show me how to get it, states it's auto adjusting but I still have nothing on screen
  • 11,361 Answers
I have LCD monitor screen & windows xp as operating system.i cannot remove auto adjusting message box. it flashes on screen after every 2-3 seconds & due to this my screen will auto adjust at every...
The message is being created by the monitor not Windows. The only thing you can do is look for the option to disable it on the monitor's menu options. NEC-brand monitors will have something call "Onscreen Notification" which you can disable. Hopefully your BenQ will have a similar option.
Mar 20, 2011 | BenQ FP71G+ 17" LCD Monitor
I cannot adjust the color on the screen. Too Blue
mcdevito75 here, On the monitor itself press the auto button for factory settings, if this doesn"t work, press the menu button for adjusting contrast, color etc. if this doesn"t work your monitor may be going bad.
Jul 17, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
The monitor wont work
plug back to vga and setup multy screan c
Jun 25, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
Gateway FPD1960 monitor
support.gateway.com/s/Manuals/Monitors/8511446.pdf OK manuals above and below. support.gateway.com/support/manlib/.../Monitor.shtml Below is how to repair your monitor step by step, hope this helps. http://www.ccl-la.com/LCDrepair10.htm
I looked for a service manual, but could find none :(
Jun 06, 2010 | Gateway FPD1975W 19" LCD Monitor
Problem is i cant adjust colour and size because of showing "LOCK
This is how:
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
User manual:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=2233BW&prd_ia_sub_class_cd=P
Apr 23, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
We have "auto adjust in progress" flashing on our screen all the time, How can we get rid of it ?
press the auto button for 5 seconds, if this doesn`t work , if you can enter the monitor`s menu and select factory settings.
Oct 27, 2009 | Dell Dimension 2400 PC Desktop
My Lg Monitor wont show screen (Power Button Flashing)
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
May 04, 2009 | LG Flatron L1750S 17" LCD Monitor
Monitor goes black
Does it show a picture in safe mode? If it does you might want to install drivers specific to the Monitor if you can find them.
Jun 18, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
HP Pavilion F1703 17" LCD Monitor Logo
135 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
