Question about Sony Playstation 3 (PS3) Console
I've been using an hdmi cord for my ps3 now i want to use a ps2\ps3 av cord do i have to change my setting on my ps3 for before i which to the ps2\ps3 av cord
    President:
  • 1,139 Answers
Please do the following :-
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you first press it and then beep again 5 seconds later. Release the power button when you hear this second beep.
Step 3. Wait for the PS3 to restart.
This solution basically resets the resolution back to standard definition and allows you to setup the video to how you want it.
Hope this helps and thank you for using FixYa
Posted on Sep 12, 2010
I used a xbox hdmi cord for my ps3 and changed my ps3 settings to be compatible. The I tried to use the av audio cord and it did not show the picture. How do I fix this?
You need to do a video reset to your system. You might have to do this every time you go between HDMI and A/V. Here is a link how. It's really easy. ^^ Good luck. P.S. It's the same for every model of the PS3.
How to RESET PS3 display output settings from HDMI HD to SD AV Cure blank...
Apr 19, 2015 | Sony Playstation 3 (PS3) Console
Toshiba 20WLT not working with PS3
The PS3 has to be configured to put out HDMI or AV(RCA plug)output.The easiest way to switch between is to connect both cords to the same TV,so you can swap to the other ouput and verify it works.(In other words,if you had the PS3 set on HDMI,you have to connect with an HDMI cord unless you change it in the PS3's settings).I think this was an energy saving solution by Sony,bacause I'm sure they could figure out how to make both work at the same.
Mar 13, 2012 | Toshiba Televison & Video
Hi our PS3 has no sound or picture. It does have the green power light on.
What is probably happening, is your PS3 is set for the wrong type of output. If you are using an HDMI cord, try switching to the AV cables that came with your PS3, and set your TV at the appropriate input to correspond with the AV hookups, and see if the picture works then.
If you are using the AV cables, it may have been set to HDMI accidentally. You need to use an HDMI cord, and hook the PS3 up to an HDMI compatible TV or monitor, and select the HDMI input. Once you get the picture working, go to Settings>Display Settings and set the display you wish to use.
May 16, 2011 | Sony Playstation 3 (PS3) Console
My ps3 was recently connected to a hdmi cord at my friends house now im back home nd i plug the av cords in and nothing is coming up its still connected to the hdmi
Hello. Sounds like you need to adjust the video output setting back to component. Go to settings, display settings, then video output setting. you may need to do this under an hdmi connection in order to see it. Once you change it to component then it will switch over to a standard AV connection.
Apr 05, 2011 | Sony Playstation 3 (PS3) Console
I have had my PS3 for bout a year now and I'm using HDMI cord and all of a sudden i cant see nothing on my screen for nght to day...why could it be?
Have you tried changing the HDMI cable and making sure none of the settings have been changed on the tv or the console? try the normal AV cable on the back of the Ps3 console to see if it works but make sure you consult your manual to see how to change from HDMI to AV and vica versa.
Nov 01, 2009 | Sony Playstation 3 (PS3) Console
Do we need a hdmi adaptor?
you need to go to walmart and buy the av cord for the ps3
its expensive but the ps2 cable wont work
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
Ps3 gets sound but no picture when using hdmi cord
you need an optical lead for the sound and hdmi for the picture
Dec 29, 2008 | Philips 23PF4321 23 in. HD-Ready LCD...
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Ps3- hdmi to av
unless there is a switch on the ps3 itself to change to normal tv, you may have to reconnect the ps3 via HDMI and change the screen resolution back to 480p or change the settings in the setup from hdmi to av.
Aug 24, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
