Question about Infinity HPS-250 Speaker
I hav my sub hooked up to a sony receiver/amplifier. on the back of the receiver there is a single RCA output for a powered subwoofer. so i used a Y splitter to feed that inot the R and L low level input RCA jacks on the back of the sub. I have had no problems for the last 8 -10 years that i have used the sub. NOw all the sub seems to do is vibrate constantly when there is something plugged into these jacks. Even if there the other end of the cord isn't plugged into the receiver (although the hum is quieter in this case).
3 Suggested Answers
Grubhead
  • 5158 Answers
SOURCE: Describe your Infinity RS-12 Subwoofer parts
Do you know for certain it is broke?
Could you have just damaged the soldering to it. RCA jack sockets are easy to get hold of at electrical parts shops such as Maplin (UK) or Radioshack (USA) or the like... You might just need to take it out to show them at the shop.
Posted on Feb 22, 2010
dunnbiker
  • 8546 Answers
SOURCE: How do u hook up
Maybe if you described the setup with exact model numbers for everything involved we might be able to answer with specifics.
You could poke around her for the Entra Manual for YOUR model.
http://manuals.harman.com/INF/Hom/Owner's%20Manual/
What they do NOT explicitly tell you is that the amp in the sub is not for your other speakers running off it's Speaker Level outputs. They're just there as a pass-through if you use Speaker Level from your own amp.
Line Level (RCA) IN to the sub will NOT pass anything out those Speaker level outputs.
Posted on Jan 13, 2011
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
How do i connect subwoofer (canton movie 125 mx) to amplifier(onkyo txnr609)? there is one subwoofer output on the amplifier with either L & R(mono) high level input or L & R(mono) low level input...
Connect front the sub out (single) on the amp to one of the rca inputs on the sub, This will work reasonably well but to make the most from the sub buy a 2 rca to 1 rca cable and use it to connect both rca inputs on the sub to the single output on the amp
Mar 10, 2012 | Canton Movie 125 MX Speaker
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
Receiver cannot recognize subwoofer
As I implied earlier, take a clue from the physical style of connectors for both parts of the subwoofer function in the old and new receivers:
RCA connections are for Line Level signal between components only.
The input (bare wire) at the speaker is for AMPLIFIED signal.
You can't just modify one to fit the other and expect magic to happen. Be glad you didn't do it the other way around and modify an amplified (speaker level) outout into a Line Level input. You likely would have smoked that component.
Your subwoofer is a passive speaker, that is, like any other speaker it needs an amplifier. Many subs are self-powered (amp built-in) and they would mate well with the RCA sub output of the receiver.
Get yourself an Active (self-amplified) Subwoofer and run UN-MODIFIED RCA cables to it, according to its instructions, from the Sub Out of the receiver. Or get an amplifier between your receiver and the sub you have.
Feb 21, 2010 | Pioneer VSX-D607S Receiver
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
Which jacks to wire the subwoofer to?
Your receiver should have an RCA connector on the back panel that will be marked "sub woofer" or "LFE out". That connects to your sub woofer with a standard RCA type cable. Also, some powered subs have left and right speaker level inputs and outputs in which you would indeed run the sub woofer through the speaker outputs. The down side of that type of connection is that the line level converter inside the sub woofer will take a slight amount of your receiver's output power, although that is rarely detectable. Also, if you have a Dolby Digital receiver, using this connection method will take away systems ability to accurately control the low frequency effects of a soundtrack.
Good Luck,
BB
May 16, 2009 | Kenwood Audio Players & Recorders
Cant get bass, fuse is fine
You don't say if you've configured the Receiver to know you have a subwoofer (under Multicontrol - SUBW YES). Unless it knows about the Sub it won't send anything out that single "preout". You can get an RCA splitter to run that single output to both inputs in the Sub.
Just as an experiment, temporarily run one a pair of cables from the REC OUT to the Sub's inputs and tune an FM station to prove the Sub amplifier is alive. If it's still silent, it's dead. If there is sound (muffled) you need to go back to the Receiver to figure out why the Sub Preout is signal-starved.
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Infinity HPS-250 Speaker Logo
    24 people viewed this question
    Top Infinity Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Jerry Greenberg
    Jerry Greenberg
    Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
