Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Can screen get warped and look like convergence problem
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
This is quite common and if you have some talent:
!) total parts cost on EBAY WOULD BE UNDER 20 DOLLARS.
2) I have start to finish, step by step instructions on what you will need and exactly how to do the repair.
If this helped or told you something you did not know, rate this solution as very helpful as I do this here for free.
If you want the instructions and where to get the parts comment on this posting and I will assist you.
SD TECH
Posted on Sep 12, 2010
Warped picture = can't seem to adjust with advanced convergence menu
Ur convergence it dead.U know how to solder right?Tries this websites for the convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Color on Panasonic 2004 is off and appears to be warped
It sounds like a convergence problem; most of these sets use two convergence IC chips that both need to be replaced; usually this can be done right in your home.
Aug 16, 2009 | Hitachi 53SWX10B 53" Rear Projection...
Picture doubles and looks like 3d
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 21, 2009 | JVC AV-56WP74 56" Rear Projection...
Curved/warped and completely out of convergence Image
Sounds like you need the convergence amplifiers replaced. Cost approx. $300.00 for expert to repair.
Jun 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
May 23, 2009 | Samsung Televison & Video
Sometimes after the my TV is one for 20 mins or so the screen warps, shooting white/pink/green lights across the top and bottom of the screen and placing a horizontal black line at the bottom like hal
Your TV most likely has a problem in the convergence circuits. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
May 19, 2009 | Hitachi 50FX20B 50" Rear Projection...
My JVC model number AV-56WP30 has a flashing convergence screen
Your TV most likely has a Convergence Chip Failure but I have not seen that symptom before.
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Weird warped lines
Try the Magic Focus option on the menu.
Jan 19, 2009 | Hitachi 57F500 57" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
20 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
