I have a gateway kav60,it does'nt have a cd rom or a floppy drive, how can fix a problem take's a disc. it say's it has a bad file or missing some files.
    Novelist:
  • 150 Answers
You will have to get an external CD ROM or floppy drive to plug into your USB port. Most electronic stores will have the CD ROM drive and Best Buy can order the external floppy if they don't have one in stock.
Posted on Sep 13, 2010
How do you flash the BIOS
What happens when you turn the computer on?
If the bios is working enough to enable you to boot from a CD download the new bios from asus along with there AFUDOS.exe flash utility and make a bootable CD and copy both to it.
If the bios is completly none functional you should be getting this msg when you turn the computer on,
Boot Block Compatible Version Ver .010
Bad BIOS checksum. Starting BIOS Recovery
Checking for floppy . .
Floppy not found
Checking for CD rom . . .
CD not found
Floppy not found
CD not found
Repeat adinfinitum.
If this is the case you need download the most recent BIOS from compaq and either copy it to a bootable CD if you have this capability or buy a floppy drive for $5 and make a bootable floppy on a working computer and copy this BIOS file to it. Then rename the bios file to A8N32SLI.ROM.
You may not even need make the floppy bootable but I would just in case.
Stick the floppy in the drive turn the computer on and you will see
Checking for floppy . . .
Floppy found.
Reading file "A8N32SLI.ROM" . Completed.
Start Erasing...
Start programing . . ./
Please turn off your system and power on again to get system back.
and happy days will be here.
Jun 29, 2012 | Compaq Presario CQ61-310US Laptop
I HAVE A GATEWAY DESKTOP COMPUTER WITH AN ERROR MESSAGE SYSTEM32\NTOSKRNL.EXE. HOW DO I FIX THIS PROBLEM?
NTOSKRNL.EXE is missing or corrupt. Issue NTOSKRNL.EXE is missing or corrupt.
Related errors
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you load the last known good configuration.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you reinstall Windows.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
http://www.computerhope.com/issues/ch000646.htm
Mar 02, 2012 | Gateway GT5026E PC Desktop
What does it mean when it says NTLDR is missing?
It's me that windows NT loder LDR is missing
if this file (NTLDR) is missing windows can not boot
so you have to make an upgrade or reinstall your operating system
vote please :)
Dec 26, 2010 | Acer Aspire One Netbook
When I turn my Gateway Profie 3 computer on, it will not boot up and displays the message: "WIndows could not start because the following files is missing or corrupt Windows^Root^\System32\ hal.dll....
Hi There,
Sounds like you're running XP bercause the hal.dll issue is almost always an XP issue. It's not the easiest thing to fix. Most often you need access to a floppy drive and floppy disc or you have to create a bootable CD that fools the computer into thinking it's a floppy with the replacement installer for hal.dll.
I recommend you read the info at the site below and decide whether to attempt the fix yourself or get assistance at your location.
http://www.computerhope.com/issues/ch000490.htm
Regards,
Selk
Nov 19, 2010 | Gateway Profile 3 PC Desktop
I have a gateway laptop (no cd, preloaded) Keep
Your missing the file from the nt detect application on the C: drive You will need to obtain a good copy of windows or find an OS that you can work around it with. I would try using Ubuntu as a live session disk and replacing the corrupted nt detection files from a disk or website.
this might help you
http://www.quickonlinetips.com/archives/2005/12/ntldr-is-missing-press-any-key-to-restart/
Jul 28, 2010 | Gateway GT4022 PC Desktop
Have a Dell 667Mhz 64mbit ram pc w/windows 98 on
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Mar 29, 2009 | Samsung SC-148 CD-ROM Drive
CD-ROM Driver Problem
CD-ROM error codes cdr101, cdr102, cdr103 Test the CD-ROM drive.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM
Installing a IDE/EIDE CD drive Ensure you have a working bootable floppy diskette with CD-ROM drivers.
Click on the above links, Follow instructions.
Should get ya back in/ Please dont for get to Vote.Thank you.
Dec 14, 2007 | Compaq Presario R3000 Notebook
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
PRINTER INSTALLATION PROBLEMS
Please check If your CD drive is detected on BIOS, if yes then Put a Windows XP bootale CD (checkout for the Service Pack) and choose boot from CD in the BIOS and go for "repair option" after the Agreement "I Agree-press F8" session. complete the installation then try installing the printer.
Oct 09, 2007 | Computers & Internet
Acer Aspire 3610 laptop - Windows XP error
on a friend's Windows 98 SE or Windows ME computer, create a floppy "Startup disk". Insert in your pc floppy drive and turn on. If floppy drive was not accessed, then get to BIOS and ensure "Boot from floppy drive" is set prior to "boot from hard drive". Once at first screen, select "Boot with CD-ROM driver". Insert CD-ROM and initiate entire re-install of Windows. Windows may do some self-restarting. At first restart do this: get to BIOS and ensure "Boot from hard drive" is set prior to "boot from floppy drive".
Jun 05, 2007 | Acer Aspire 3610 Notebook
Computers & Internet Logo
228 people viewed this question
David Payne
David Payne
