Question about Kitchen Ranges
My boat goes in backwards when i put it in gear and when i put it in reverse it goes forward. what could be the problem?
My guess is you have the wrong prop on your boat. You need to check if it is a right or left prop. Right hand prop will spin clockwise if you are looking at it from the rear.
Posted on Sep 04, 2011
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
My car goes into reverse but won't go forward. What's the problem?
10 Most Common Transmission Problems
www.transmissionrepaircostguide.com/10-common-transmission-proble...
A similar type of thinking goes into diagnosing car trouble. ... response issue, but after shifting into gear the engine's RPMs will surge, but the car won't move ..... Can anyone please explain why my car cant go in reverse but can drive forward
My car will not go in reverse but will drive forward. What could ...
https://answers.yahoo.com/question/index?qid...
Dec 26, 2007 - My car will not go in reverse but will drive forward. ... I tried putting it in neutral and pushing it backwards, but something catches and it won't budge. ... Either way, it's likely that the transaxle is going to require removal and ... the hood and movethe linkage by hand, then it would shift into gear ok for awhile. Why won't my truck go forward, it only goes in reverse? ' Yahoo ...
Feb 23, 2014
My car won't go into reverse, still okay to drive a 2 hour drive ...
Jan 12, 2011
My car won't go in reverse but it will go forward with no problem ...
Feb 6, 2010
My car will drive forward, but not in reverse... Could this be a ...
Sep 11, 2007
More results from answers.yahoo.com
Dec 16, 2015 | Cars & Trucks
In turbo hydro 700 why would forward gears make the rear wheels go in reverse
Your differential is upside down. Ford model T's had the same problem. It was possible to mount the rear axle upside down which made the car go forward in reverse and backward in forward gears.
Mar 07, 2015 | Cars & Trucks
Shifter moves on big bear 350 but quad wont reverse now it goes forwards
for some reason you are not getting into reverse , there is no real reason it should stay in forward gears unless there is someting wrong with the shifter itself being in the wrong position this can happen take it off and reposition it and make sure your clutch is disengauging to shift gears , will it go into all gears or just 1 forward , ck into that and be a little more specific on the problem ,good luck
Mar 18, 2014 | Grizzly Big Bear Atv Maintenance Free...
Mercury outboard 70 hp 1987 when in forward gear the prop turns one way when in neutrel spins both ways when in reverse the prop is locked both ways is my lower unit working property
mercury and others have a "sawtooth" cut for forward gear so the prop will rachet spin backward when dry tested, and a square clutch dog for reverse, which when it finally engages locks the prop in reverse. and will not spin in either direction.
So when you shift--- snap in in gear-- do not ease it in gear, as it will wear the dog out faster.
Sep 27, 2012 | Boating
98 vw beetle wont go in reverse
I have a 1998 and I just confronted the same problem. It seems to take like 1 gear in reserve and like 2 gear in 1 gear. Any thoughts? I don't really it should be the transmission since it still works going forward in 2 different gears. Thanks.
May 13, 2010 | 1998 Volkswagen Beetle
Mercury 115 problems
This could me that reverse gear is not fully engaged.Adjustment on the cables is needed.Take the cowlings off.With the motor not running,move the throttle/gear selector into forward and reverse.You will see where the cables move in the engine area.Note which way the cable moves the selector when reverse is selected.Do this next bit from inside the boat.Hook up the flusher to the motor and start it.Select reverse.When you hear the grinding,push the selector by hand in the direction of travel.It should engage the gear fully.You will see the adjustment threads on the control cables.Move to suit.Hope this helps
Jul 28, 2009 | Boating
FORWARD AND REVERSE GEAR SELECTION BACKWARD
Recheck your belts, does your engine have a pto
Jul 28, 2009 | Garden
Kitchen Ranges Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
