Question about Handspring Treo 90 Handheld
TREO 90 Backlight
The backlight on my TREO 90 quit working.
  • Misterhat67 May 15, 2008
The Treo 90 had a problem with backlight failure, which Handspring acknowledged and began fixing back in 2002.  However, their guideline was that if your 90 did not fail within 6 weeks of use, it did not have the defective part responsible for the failure.
Your backlight probably has just died of old age.  It is EXTREMELY difficult to replace just the backlight (I've tried).  If you search long enough on eBay, though, you can probably find a 90 with a broken case, dead battery, broken motherboard, or some other ailment, but with a functioning screen/keyboard assembly, including backlight.  It's a pretty simple matter to replace the screen/keyboard assembly (there's a screw hidden under the battery that holds it into the front frame).
Posted on Jun 26, 2008
Screen is not working?
If the screen is black, then with computer on, shine a strong flashlight on the screen at about a 20 degree angle (90 degrees would be pointing the light right at the screen). Move it around to see if any of the expected graphics (e. g., login request) are visible. If so, your backlight is not working, but everything else is fine. A backlight failure is usually due to a dead fluorescent tube, but sometimes is the result of a bad inverter. If you have an LED backlight, check the LED driver circuit first.
Jun 25, 2014 | Lenovo ThinkPad Tablet 2
Toshiba satellite backlight
Mohammad,
Toshiba Satellite P100 screen Inverter replacement;
1) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
(You can click on any photo to enlarge it. At the top, and bottom of the page are the page numbers. They are in white; Page1 :: Page2 :: Find another model )
2) Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight (Present technology) is a CCFL, or a series of LED lights.
The Toshiba Satellite P100 series of Notebook PC's uses a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average size is approximately 2mm Thick, and the length is close to the height of the LCD screen. 2mm is a little larger than 1/16th of an inch.
This means the CCFL can be broken quite easily, as it is fragile. (You also DO NOT want to be cut by a Fluorescent lamp )
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
A screen Inverter converts the power from the laptop, for the Backlight, and LCD screen.
As previously stated in a Clarification, 90 PERCENT OF THE TIME the fault is the screen Inverter.
Regards,
joecoolvette
(I never request commendations, but thank you for offering.
We, the older techs here, feel that is begging.
3 years at FixYa so far.
Regards,
joecoolvette)
Mar 23, 2012 | Toshiba Satellite P100 Notebook
Viewsonic vp2000s LCD computer monitor - no image displayed; possible backlight outage.
It is possible that the backlight has quit working. Use a flashlight, held at an angle to the display, to see if there is a faint image visible. If so, then have backlight repaired. Otherwise, try a different input / cable.
Aug 17, 2010 | ViewSonic VP2000s 20.1" Flat Panel LCD...
The backlight will not turn on. I have tried a hard reset but still have nothing
Try changing the display brightness.
Press "Function" + "P" and change it with the left and right controller on Treo's center. By "Function" I mean the lower left keyboard key.
My Treo started doing this a while ago, sometimes the backlight simply goes off. I found that this is more frequent when you use a high brightness setting.
Dec 17, 2009 | Palm Treo 680 Smartphone
My Treo 755p backlight wont stay on if turned on, it only comes on for a second and goes off thereby making it difficult to see
Hello i have a sprint treo 755p here are steps for making it brighter and stay on i have they same problem
PRESS AND HOLD WHITE BUTTON AND HIT P AND IT HAS LIKE A SUN LIKE ICON AND USE THE 5 WAY NAVIGATOR TO THE RIGHT AND IT WILL PUT THE BRIGHTNESS UP AND STAY UP!
SAAHBOBBY
Sep 29, 2009 | Palm Treo 755p Smartphone
The backlight will not turn off on my palm treo 750
Try shutting it of, removing the battery, waiting 10 minutes then replace the battery and turn it on again. This should fix your problem.
Sep 22, 2009 | Palm Treo 750 Smartphone
The backlight just quit working on my Toshiba Laptop
The backlight problem can be caused by a faulty inverter or a faulty/worn out CCFL lamp.
These parts are available from the Internet. I found LCD Parts a good company to deal with. Check them out for parts,service and DIY info.
Use this link :-
www.lcdparts.net
Sep 14, 2009 | Battery Technology for Toshiba Satellite...
Palm Treo 680 Screen Backlight went out
it is not the screen. I just bought a brand new screen and installed it. But the backlight still does not turn on
Mar 13, 2009 | Palm Treo 680 Smartphone
Acer laptop
This is probably caused by a bad "inverter" board inside the screen housing.Don't worry they are relatively inexpensive and easy to replace.
However, some laptops have a failure on the motherboard which causes the backlight to go out,because the inverter,which powers/controls the backlight,depends on power and a PWM signal from the motherboard.
Backlight problems are almost never caused by the backlight itself.
Jul 31, 2008 | Palm Treo 680 Smartphone
Treo 600 Completely Blue Screen
I's sorry to tell you your screen is dead. The screen is not displaying any information but the backlight is still functioning. This is the most expensive part of the phone as far as replacement parts and after-market parts. If you can fine one that is a reasonable price, you are very fortunate.
I have three screens like this at home. There are three layers to the screen, the backlight, the imager, and the digitizer. All three sandwiched together create the screen.
If the phone was on when you fished around the charge port, it is possible that you inadvertently caused a charge or grounded the charging/power circuit. You are fortunate that only the screen was damaged...if that's the only part that is damaged.
Apr 26, 2008 | Palm Treo 600 Handheld
Open Questions:
HotSync Problem on Treo 90 When I press the HotSync on the Trio 90 cable (I do not use a cradle) in place of the moving red and blue arrows moving, the Microsoft Unplug or Eject Hardware icon appears in the lower right portion of the task bar. I assume this means that contact has been made between the Treo 90 and the PC. This icon remains until I receive the following message on the Treo 90: “HotSync Problem” “The connection between your handheld computer and the desktop could not be established. Please check your setup and try again. This problem began after I updated to WinDesktop_401_ENG_V, Treo90Updater11, and PMStdUpdate3171. I downloaded USBRegClean.exe and used it. Then I reinstalled WinDesktop_401_ENG_V and the problem continued. I emailed my log to Chapura Support. Unfortunately, this was done after I had uninstalled and reinstalled everything and the log did not show here a Synchronization had been established because after the reinstall, I have been unable to Synchronize. I checked the PalmOne knowledge base and did the following: I checked to make sure the cable from the HotSync was is securely attached to the USB port in the back of the PC and that the cable was securely in the Treo 90. I click on the HotSync manager, (Double arrow icon on the bottom right corner of computer screen), click on setup and then local tab and first set it to PC overwrites Handheld, this did not work, I then reset it to Synchronize, this did not work, I then reset it to Handheld overwrites P.C. This did not work. I also changed the speed settings to 9600. This did not work. I did a soft reset of the Treo 90. The reset took place, but the problem persisted. I did a hard reset, then uninstalled and reinstalled everything. However, when I try a HotSync, I keep getting the Microsoft unplug or eject hardware icon. I uninstalled all UBS ports. The problem continued. Chapura Support suggested using PalmOne’s HotSyncCheck which I interpreted to be the “USBRegClean.exe” and used it again and then reinstalled WinDesktop_401_ENG_V successfully. However, when I reinstalled Treo90Updater11, and PMStdUpdate3171, when I attempted a HotSync it failed and I continued to get the Microsoft Unplug or Eject Hardware icon. Is there a fix? Is it possible that the problem is physically located in the Treo 90? If so, where can I take it to be checked and serviced if necessary? Thank you for your attention to this problem
Feb 27, 2017 | Handspring Treo 90 Handheld
Handspring Treo 90 Handheld Logo
285 people viewed this question
Top Handspring Computers & Internet Experts
ray gallant
Are you a Handspring Computer and Internet Expert? Answer questions, earn points and help others
