Question about Royal VF1012mx Shredder
I did not empty the shredder soon enough & now the drawer will not open. Is there a way lift off the top without messing up the machine?
    Genius:
  • 1,218 Answers
Try tilting the shredder forwards and pull the waste bin out as much as you can...you may have to reach in to try to pull some of the "compacted" paper out of the waste bin...once you remove some of the paper then the waste bin should slide out more freely. This may make a bit of a mess while fishing out the paper.
Posted on Oct 06, 2010
  • gwtobey Oct 06, 2010
    Thanks for the suggestion. However, the drawer would not come out more than a tiny fraction of an inch. There was no way to get my finger or even a piece of paper into it.
    I did finally solve the problem by turning the machine upside down
  • abp20 Oct 06, 2010
    Glad you got it open and emptied...seems to be a common prob that people fill it too full then have difficulty opening the waste bin.
We missed emptying out the machine, now we are not able to open the drawer. What can we do?
Try shaking the machine to lower the cuttings in the bin. You might have to pull really ******* the bin to remove it. Be careful you do not break handle on the bin. The machine should have stopped shredding when the bin full sensors were activated, if they did not , then you have bad sensors in the unit and they should be replaced.
Aug 30, 2011 | Fellowes SB95C Cross-Cut Shredder
Fellowes S8-95C is full, but can't get it open. Help!
I was able to pull really hard and open the bin 1-2". I turned the unit on its side over the trash can and some shreds came out. I alternated shoving a sturdy metal rod inside (first an aluminum architectural ruler then the longer handle of a squeeze clamp) to loosen up the shreds and tipping the machine on its side to get some loose shreds out. After doing this enough times I was able to dislodge the dense clumps and remove the drawer. Now that the machine is empty there is a red light on and it does not shred.....UPDATE: turns out somewhere along this rough process (paper was in rock solid clumps) a small piece of the door that presses the "door closed" switch broke off. Jammed a piece of cardboard in there and it shreds again, although it does not automatically turn off when the door is open.
Jun 30, 2011 | Fellowes SB95C Cross-Cut Shredder
Au845xb how do i open it to empty?
there is a lip at the top of the tiny window on the front. Pull it forward like you would pull a file cabinet drawer open. it might take a bit of muscle if it's jammed full of shreddings.
Nov 29, 2010 | Aurora Electronics AS1018CD Shredder
Need to empty, how do you open it?
The bin just pulls out but if you cant open it then it is probably "overful" with shredded paper...in extreme cases I have heard people say thay turning the machine "upside down" let them get the bin out.....be aware of the mess this will make.
Nov 20, 2010 | Royal 150MX Cross-Cut Shredder
LG Front Loading washer detergent drawer is jammed and will not open
you're in a bad spot. you will need to remove top metal panel of washer; and carefully separate the drawer housing a little and wiggle the drawer out. one of the compartments in the drawer popped up and jammed the drawer.
Feb 15, 2010 | LG WM-2277HW Front Load Washer
Dredge drawer full and it is empty
Hi
One thing you want to make sure you do is leave the machine on when you remove the drege drawer other wise the machine doesn't know that you emptied it. Remove the drip tray and pull the empty drawer out about half way and leave out for 15 seconds. Then push the drawer back in from the right front side with 1 finger. That way you make sure that you engage the switches in the machine. If you slam the drawer in you can pull it away from the switch and it will say drege drawer missing. If you put the drip tray back in, it can sometimes lift the drege drawer and disengage the switch. There is a notch in the right side of the drip tray that has a flashing on the back side of it. You can remove about an 1" of the right side of the flashing and it will stop the lifting of the drege drawer. Remember to leave the machine on when you empty the drege drawer other wise it doesn't know.
Jul 17, 2009 | Saeco Royal Professional Espresso Machine
The drawer to the shredder will not pull open
You have to get the drawer out to get to the screws holding the top on.
May 07, 2009 | Fellowes Powershred 120C-2 Shredder
Short run time and redlight, stops running Fellowes DM15C
There are two sensors (look like little light bulbs) on the top part of the shredder at either end of the blades. If you pull out the drawer and turn the shredder upside down you will see them. They get dirty telling the machine that it is full and needs to be emptied. Clean the sensors off with an alcohol wipe. If cleaning them does not work you need to replace the sensors.
Aug 25, 2008 | Fellowes DM15C Shredder
How to empty a Tech Solutions TS8000 shredder
Pull the top of the basket toward you and the top of it should swing out. Then you can lift the basket up and out once the top of the basket is partly open. Hope this helps. Have a good day. Mac =)
Mar 09, 2007 | Tech Solution TS-8000 Cross-Cut Shredder
Royal VF1012mx Shredder Logo
118 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
