Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
I have a craftsman push lawn mover it will run for a few moments and then it will cut off. It also used to start with just one pull of the cord and that is no longer the case. Why do you think it wont stay started. I changed the oil, put in new gas and replaced the filter and it still will not work. What should I do?
    Problem Solver:
  • 11 Answers
Check to see if it has a fuel cut off switch if so turn it on but if not check to see if the cabuerator is getting fuel if it has a prime button on it push it a few time too put fuel into the cabuerator then strat it up if it start to go dead then work the chocke but do not countiue prime the cabuerator bcuz u will flood it out if u cant get it to work still check ur spark plug to see if it has filed out if so replace it.
Posted on Sep 13, 2010
How do I fix a Craftsman gas-powered push lawn mover that won't start? Already tried a new spark plug, and there is gas in the tank. Engine doesn't even begin to turn over
You need to add more info. When you pull the cord does the engine spin? If not the engine is seized or there is something stuck in the blade or the blade brake is stuck on.
If it does spin the take the spark plug out, attach the wire to the plug, lay the plug on a metal part of the engine and pull the cord. You should see spark jump across the gap. If you have spark then you have no fuel getting into the engine.
Dec 14, 2011 | Garden
Craftsman 917-377150, the pull cord broke and the housing to replace it is rivited in place, can I drill these out, but then what?
Remove the recoil assembly from the mower, there are 3 machine screws.
Remove the old rope and get matching cord, make sure you get the correct diameter, usually 3/16 or 1/4 inch, and type, I believe it should be nylon braided. Do not cut the new cord.
Use a match to light the end of the cord and once it ignites, use an old rag to pull and form the end into a point.
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
Jul 30, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Pull cord broke on my craftsman gas push edger. I replaced cord but when I pull cord..It wont rewind but I can hear it trying to start
It sounds like you did not properly rewind the spring that is behind the spool that the cord would around, that spring is what rewinds the cord after pulling the cord.
May 05, 2010 | Craftsman Garden
Lawn mover will not start, was flipped over
The clicking noise may be the blade hitting the side of the mower or it was not put on properly. It needs a balance to the aluminum flywheel on top of the engine. The blade adapter and blade provide this balance for the engine to run.
Good Day.
Oct 07, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
I can't disingage the lever to cut grass on my craftsman riding lawn mover. Now because of this I can't start the mover.
the lever moves an arm on the deck connected to a pivoting plate holding the idler pulley. when you push up the lever, it pulls the pivot [and idler pulley] back and puts tension on the belt. if this pivot gets rusted, it sticks and won't release tension on the belt. find the pivot point and lubricate it thoroughly with oil, wd-40, or liquid wrench, then work it back and forth by hand until it is freed up
Aug 02, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
My craftsman rotory lawn mower 6.5 hp self propeled walk behind cuts out afater starting a few seconds . model# 917.377070
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
Aug 02, 2009 | Craftsman Garden
Craftsman Walk behind lawnmower
usually theres just a few bolts to take off on the top, and the whole rip cord assembly will pull right out, allowing you to install the new one.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Honda, self propelled lawn mover. GVC 160. Used
Could be Flywheel Key, Coil and Do buy a New Spark Plug. Make sure Head bolts are tight.
Jun 26, 2009 | Garden
18.5 sears craftsman yard tractor won't run right
The fuel filter needs replaced or the carburetor needs cleaned.
Apr 07, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
102 people viewed this question
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Adam Jasar
Level 1 Expert
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
