Question about E-Machines eMachines Desktop PC
I have an e-machine T2792. It boots up fine then runs for 10 to 20 min. then shuts down. Could this be my cpu going bad? Thank You Scott
    Scholar:
  • 181 Answers
CPU, the motherboard and the rest of the chips in it is subject to wear and tear. This is in addition to the high temperature it is operating with. The sudden shut down is cause by a failure of one component (usually the Processor) who's burned out.
Posted on Sep 13, 2010
Testimonial: "Thank You I will start with the CPU"
    Problem Solver:
  • 7 Answers
Cpu ,over temperature/smps low power problem.first one check fan and reset .you can't try and contact service person...
Posted on Sep 14, 2010
Used ups system w/new & charged batteries,run time=160 min. shuts down in 2 min.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 24, 2012 | Computers & Internet
Sony Vaio has started shutting down unexpectedly. Restart in safe mode and run event log with no results returned. Shutdown and restart. Starts normally but then shuts down within 2 min. Repeat process,...
Your pc CPU FAN is not working, you need open it and clean fan,, and under fan, on CPU there is termo cream, don't frgot about it, you need clean it and put new termocream. it is nessasary for cool CPU, that Cpu can not be warm.
Jun 11, 2011 | Sony VAIO Laptop
Emachine t6420 suddenly shutting down after about 15 min. - 1/2hr. Power button on HD blinking on and off slowly. Can get it to start up again by taking out the electric plug and waiting a min. and...
Check on the processor installed inside the computer's motherboard, it might be loosen and make sure it is properly locked. Also check for the fan. Make sure the cpu is properly ventilated to avoid overheating that might cause the shutdown.
Sep 28, 2009 | E-Machines T6420 PC Desktop
Optiplex 260 keeps shutting down ,when unplugged for approx 30 mins it boots up again
Check power supply (caps going marginal or bad, bad solder joints)- swap out w/ known good, if problem persists, it's either components on the motherboard, probably near the CPU, or solder joints; have you checked your standby/hibernate settings are proper in the BIOS and OS?
Aug 12, 2009 | Computers & Internet
Hello, I have an E-machine D4362 that has started intermittently shutting down. I did some troubleshooting & found the CPU and case fan not running while the machine is up & running, the CPU heat sink was...
POWER CONNECTOR ON MOTHERBOARD HAS GONE BAD. CHEAPER TO REPLACE BUT CHECK MANUFACTER TO SEE IF UNDER A WARRENTY.SOME WILL GIVE CREDIT ON A NEW BOARD.
Nov 29, 2008 | Computers & Internet
Gateway mx3215 freezing on init boot
Corrupted driver or faulty hardware perhaps.
May 08, 2017 | Gateway FPD1975 19" LCD Monitor
Hp pav 64702
the above posted some possibilities.
most likely candidates are either failing power supply (a cheap replacement...30 bux or so) or overheating
is there lots of dust on the cpu fan? which fan is not spinning, one on the cpu or motherboard?
of if the above done work then its a bad board and you gotta buy a new one ;\
thoes are really the only whatiffs here.
Apr 14, 2008 | E-Machines T2792 PC Desktop
Shut down
Check to make sure you're not going into Stand-By mode. Click on the Start Menu....Shut Down and make sure you're not clicking on Standby.
Feb 23, 2008 | E-Machines eMachines Desktop PC
E-Machines T2792 PC Desktop is not booting
This could be a corrupted bios, look on the motherboard for the 'JBAT1' terminal and put the plastic jumper cap from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. Start the pc hopefully and press F2 or DEL to enter the bios and set the time and date in standard bios settings and look for the auto detect drives and select it. press ESC and and save settings and it will re boot and go into windows if the softwaere was not corrupted when it was turned off at the button.
Jan 30, 2007 | E-Machines T2792 PC Desktop
E-Machines eMachines Desktop PC Logo
183 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
