Son weed eating and hit wire outside now have no eletric to thermostate and wont come on wire is not broke into
  • 674 Answers
The transformer may be shot. Place the fan switch on the thermostat from auto to run. The indoor fan should come on. If it doesn't then the transformer is probably bad. You can check for power on the transformer primary and then the secondary. If you have power on the primary and not on the secondary then it is no good either.
Posted on Sep 13, 2010
What does a manatee eat?
A manatee is a herbivore and eats over 60 different freshwater (floating hyacinths, pickerel weeds, alligator weeds, water lettuce, hydrella, water celery, musk grass, mangrove leaves) and saltwater plants (sea grasses, shoal grasses, manatee grass, turtle grass, widgem grass, sea clover and marine algae). Hope this helped.
Mar 25, 2015 | Miscellaneous
Should i weed eat high weeds before appling weed killer
yes--have to be growing to get the chemical in the plant
Jul 30, 2012 | Roundup "" Weed & Grass Killer
Cut outside wiring with weed eater and wont allow unit to come on
Hello,you can splice the wiring or just run new wire from the R and Y terminals on the control board to the contactor coil on the outside unit.
Aug 12, 2011 | Heating & Cooling
I have an intertherm a/c outside unit. I cut a small brown wire weed eating. I spliced the wire, but the unit won't turn back on. Is there a reset button?
Check the wire carefully as it is most likely broken where you can't see it. or you have more thatn one wire broken.. this is very stiif wire and often break behind the insulation .
Jul 17, 2011 | Heating & Cooling
My goodman heating unit with heat pump keeps blowing fuses. I have put in fuses of the same size that was in it. The bower attempts to kick on and then the fuse blows everytime. what could the problem...
There is a short somewhere in the wiring, the most common being the outside condenser wires. Follow the wires as far as possible to see if there are any bare or cut wires visible. You would be amazed how many times I have fixed this problem from people hitting it with a weed eater! The short could be anywhere, but I would start outside. Be sure to inspect the board for any burnt looking sections too. Home this helps and good luck!
Feb 04, 2011 | Goodman GMS90703BXA Heater
Ac unit will not come on
pull the fuse/breaker disconnect panel outside by unit and main breaker inside,remove compressor access panel,re-power unit trace your thermostat wires to the terminals by compressor and short the two term together and see if unit starts,sounds as though you broke wire in more than one place.good luck be careful doing this,its 240 volts at most compressors on a central A/C
Aug 02, 2009 | Heating & Cooling
Ac wont power on . fuse on board keeps blowing out. there power going everywhere else but board.
You have short somewhere. Take all low voltage wires loose outside and replace the fuse. Sometimes you have wire touching or someone took a weed eater to your wires. Ruiss
Jul 30, 2009 | Heating & Cooling
My airconditioner for the house is not working we change the electronic thermostat an still not working we replaced the fuses an its not improving would it be because of my dogs eating the wire's that are...
there could be a short in the wire. meaning that its not getting the proper voltage. do you have any other symptoms? make sure that the breaker is not tripped, and if it is, it very well could be from the dogs eating at the wires. that could also kill your dogs if they get hit with that voltage coming from the wries.
Apr 22, 2009 | Goodman CKL24AR24 Air Conditioner
Ac unit central
Sorry, we don't have water cois in our area.
Aug 07, 2008 | Goodman CLQ36AR49 Air Conditioner
Condensing unit
Probably one of the wires going to the control board or contactor has been pulled off when this happened. If you feel comfortable trying to reconnect these comment me back and I will try to walk you through it. PLEASE REMEMBER THAT THE CONDENSER HAS HIGH VOLTAGE INSIDE OF IT.
Jun 27, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
