Question about Dryers
Admiral Ultima Gas dryer model # AK76003 - Dryers
2 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: Dryer is not heating timer
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to. If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 24, 2008
How to replace belt on admiral dryer model aed4675yq0 ser.m217 20305
Go to YouTube. There are several videos on working on admiral or Whirlpool dryers
Sep 20, 2017 | Admiral Dryers
Admiral dryer wont heat, will run. Continuity on all wiring....what next?!
gas dryer check the thermocouple ---electric check the heat element
Jul 31, 2016 | Admiral Dryers
How do I take apart admiral dryer model ade7005ayw
You can use Google search your model numbers an it show you a video on how to take your dryer apart the right way .
Mar 03, 2015 | Admiral Dryers
I have an admiral dryer, model #ade7005ayw, that will not tumble. the motor will spin manually and the belt is brand new and properly installed. what could cause this problem?
This Admiral site lets you select symptoms, offers solutions, has videos, and instructions, plus authentic parts for ordering.
Worth a look.
My ADE7005AYW Model Overview from PartSelect com
http://www.partselect.com/Models/ADE7005AYW/Symptoms/Will-not-tumble/
Feb 28, 2015 | Admiral Dryers
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 02, 2013 | Admiral Dryers
Going from a 3 prong to a 4 prong dryer plug
Admiral AED4475TQ is an electric dryer? Was your old dryer gas? If so, you need a 220 line installed to run the electric dryer. Here is a link to instructions from ehow http://www.ehow.com/how_5824435_wire-220-plug.html.
Jan 13, 2013 | Admiral AED4475TQ
Need help putting new belt back on Admiral dryer model ADG 7005 AWW, possibly a diagram?
Hi bgpace02669..
To to this webpage to see a picture of how to route your belt.
Please take time to rate me
http://www.expertappliance.com/dryerbeltconfiguration.html
Jul 09, 2011 | Maytag ADG7005AWW Gas Dryer
I have a Admiral Electric Dryer -Super Capacity, Stainless Steel Panel. How do I get the belt off to replace.
Interesting question. You know in recent years Admiral have been acquired by Whirlpool. Several tried and true base models have the Admiral logo on them now so it would be a guess as to which model you have. Why not post a follow up and add the model number ?
Apr 01, 2011 | Dryers
Dryers Logo
103 people viewed this question
Top Dryers Experts
