Question about HTC Hero Smartphone
My battery does not charge on the HTC hero and it says that its overheating with the two led flashing lights green and orange. The battery isnt even hot when it does it but I can barely ever charge my battery
  • 358 Answers
Hello, why the phone is not charging is because the cell of the battery is weak and can power on the phone for to long, that's why it shots down so quick,
You will need to replace battery with a new one for longer talk hours.
Make sure you charge battery for 6hours before use.
And also if the battery still doesn't work that means the phone memory is weak and it will need to be flashed to restore back the phone memory.
What you will need to do is this,
You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Posted on Sep 12, 2010
Htc evo 4g turned off and wont turn back on and is flashing orange and green lights
That ussually means the battery is overheating! Take the battery out and wait 30 minute to put back in, but don't turn the phone on. Start charging it again, and if it continues to flash, take it to your provider IMEDIATLY!
Jul 14, 2013 | HTC Cell Phones
Hi, what is the flashing light on my HTC wildfire screen ? sometimes it's flashing and sometimes not so could you please tell me how it works normaly ? thank you
i think you mean the led above the screen. it is a led that means a lot of things
like: orange - recharging green - full battery red - low battery
there are more things like notifications for text messages (all apps can make ir blink for their own reason)
hope this helps
Feb 20, 2011 | HTC Wildfire Cell Phone
My htc wont open and when i connect charger, led light goes red what happen?
Maybe your battery is dead and will not charge. Normally when you connect the charger the led must become orange after a few seconds and green when the battery is fully charged. If it stays red the battery is not charging.
Jan 24, 2010 | HTC Touch Dual Slider Smartphone
I have htc p3300. once started charging its get switched off automaticaly
does the charge light stay on (orange led) on or does it go green or flash on-off orange?
could be battery issue..
on the charge slot on the bottom of p3300 there will be 2 bins left and right inside. try bending them slightly - ONLY slightly tho incase it snaps.
use a needle.
its wat im doing at the moment, im currenlty trying to figure this out so ill keep you informed if i find the soloution.
atm i have to have my phone on charge to use it, otherwise it just goes off but thats how im getting it to charge atm.
if im not in touch..
raving_nanza@hotmail.com
Oct 28, 2009 | HTC P3300 Smartphone
HTC S710 Smartphone not switching on
The battery is flat.
If the battery is very flat sometimes the phone will not start charging or turn on even when a power cable is connected.
This worked for me:
- Remove battery
- Insert power cable/usb cable
- Orange charge light should start flashing
- Re-insert battery
- Leave phone charge for a couple of hours
- Turn on
Feb 03, 2009 | HTC S710 Smartphone
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
HTC Dash
solid green means battery is fully charged
top LED flashing green means connected to your network ie bt ,o2 ,
BOTTOM LED flashing connected wi fi network
Sep 08, 2008 | HTC S620 Smartphone
HTC PPC-6800 Smartphone errors
Okay take out battery and put phone on charger .. then try a hard reset . and then go to a soft reset. after that put battery back on and soft retset and see if it works .
Jul 04, 2008 | HTC PPC-6800 Smartphone
Dell Latitude C610 battery claims its too hot to charge....
The charge light flashing orange-orange-orange-green....-orange-orange-orange-green.... usually means the battery has reached the end of its life and now it needs replacing.
There are three ways to test your battery:
1) If the battery has a button on the bottom of it and a row of 5 leds, then push AND HOLD the button for 5 seconds. The LEDs should all turn OFF, then turn back on showing a pattern. If all five LEDs turn on, the battery is dead.
2) Open the Dell Quickset application (doubleclick it in system tray), go to Battery Meter, go to the battery health tab, and pick your battery. It should tell you there if the battery is healthy or not.
3) Reboot your computer and go into the bios. Pick the Battery tab in the bios. It will list the battery health there.
Jan 20, 2008 | Computers & Internet
HTC Hero Smartphone Logo
730 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
