Question about RCA CC-VHSCAM Camcorder
Need rca CCD Pro Edit adapter/charger. solid state image sensor. red light on adapter comes on but dont have a battery.power on camera wont come on.
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
localwonder
  • 6784 Answers
SOURCE: RCA HD27F754T 1 Solid Red Light, then,
HI. this may be a fly back situation. this is a transformer that is located on the power board section of your set. This device stores and, distributes the necessary AC current needed for proper CRT performance. There is also a horizontal deflection chip that will shut off the transformer if it becomes unstable as well.
I recommend checking the Horizontal deflection chip for damage. if this chip is in good condition, replace the HV Fly back transformer.
Posted on Jun 26, 2009
jtrag
  • 112 Answers
SOURCE: RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Posted on Jul 21, 2009
walesarumi
  • 6993 Answers
SOURCE: rca tv modle #27v414tyx8. wont
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 12, 2011
SD Tech
  • 14553 Answers
SOURCE: Have a RCA flatscreen model # L40FHD41, blue power light comes on and stays solid but I don't get any picture or sound. Screen stays completely black as if it doesn't have any power at all.
Other than checking all the connections going to it for signal it is likely a shop repair.
The nature of these sets is someone must open and inspect them and check for voltages missing.
At that point it becomes a guessing game---try the boards (purchase them) and see if a bad board.
It is always possible the front screen unit or display has failed which is fatal cost wise.
You have to weigh the cost of repair, age of set and cost of replacement in this.
The only way anyone can KNOW which board is bad is to actually remove and replace it----most shops look at it and shoot you a high estimate.
let me know if you have questions.
Posted on Mar 14, 2012
How do u charge the camera? What does the charger look like?
You can charge the batteries in three ways
1. Using an AC power adapter. Connect the AC power adapter to the camera trough the power adapter connector below the usb connector on the right side of the camera (looking from front). Then connect it to the AC power outlet.
2. If you have an optional HP Photosmart camera dock, plug the camera in the dock and then dock the camera. Same thing if you have a wireless dock.
While the battery is charging, the battery charging light in the camera blinks. Once the battery is fully charged, the blinking light stays solid.
It is better that you read the user manual for the camera. If you dont have one, download it free from the web: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
The charging procedure is given with figures on page 6.
Jan 10, 2011 | HP Photosmart M525 Digital Camera
Screen wont come on
Does it only light up when you adapter is plugged in? If so try taking out the battery and making sure it is in correctly. Press the power button under the screen on the side if the unit and the middle circle in the directional key pad, there should be a menu that comes up.
Jun 17, 2009 | Jazz DV-179 Digital Camera
DSC-T1 LCD looks like I'm looking thru night vision goggles!
Its problem of bad ccd imager in DSC-T1 and ccd imager will be replaced.
Sony announced free of cost repair scheme for ccd imager problem in DSC-T1 and you can see details on Sony CCD Support.
Jan 27, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Cant charge my battery
i have same camera.. but i dont think this is a problem.. while charging light keep flash.. when it completes charging it shows u solid red light..
Dec 25, 2008 | Nikon Coolpix S550 10 Megapixel Digital...
NV3 Camera - won't turn on or charge
have been having the same problem. Just pulled the lead out straight and stretched it and now it is charging red light on constantly. May have been a kink in the lead?
Jun 24, 2008 | Samsung NV3 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Sony ccd-f55 Handycam
If it is a CCD-F555 the battery charger is also the AC Power adapter. There is a switch that states VTR...switch to it and plug into the camera and it should work. Have you had any other problems with your camera. I got mine in Japan when I was stationed over there and it will play back the tapes; however, it will not show the camera in the viewfinder. I know the lens is working because it will autofocus. I just can't see it. My email address is ds4190@excite.com
Dennis
Apr 26, 2008 | Sony Handycam CCD-F555 Camcorder
Exz700 wont charge
When you put in on the charger the light should stay a solid red color. If it blinks that means you are having a battery issue. If the light doesn't come on at all then you either don't have it plugged into the wall outlet or you are having a charger issue. Either way you need to call tech support and they can either replace the battery for you or have you send in your charger to have repairs look at it to see if there is something wrong with it.
Apr 26, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
The battery wont charge
i had the same problem.
if your battery light is blinking a red light then you should call up casio's technical support and they'll send you a new one within 2-5 business days:)
call 1-800-435-7732 for technical support! :)
Apr 01, 2008 | Casio Exilim EX-Z77 Digital Camera
RCA CC-VHSCAM Camcorder Logo
231 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
