Question about Apple iPod nano
Ipod help The hold button on the ipod isn't switched on, but it shows that it is. How do you fix this?
Low battery
Posted on May 15, 2008
My iPod turns on but the buttons dont work! They were working just fine then they stopped! How do i fix it?
Try this! http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_nano.htm Difficulty: Easy Time Required: Less than 1 Minute Here's How:
  1. NOTE: First make sure that your iPod’s hold button isn’t on. This is the little switch at the top left corner of the iPod video that you can move to “lock” the iPod’s buttons. If this is on, you’ll see a little orange area at the top of the iPod nano and a lock icon on the iPod’s screen. If you see either of these, move the switch back and see if this fixes the problem.
    If the hold switch wasn’t the problem do the following:
  2. Move the hold switch to the on position and then move it back to off.
  3. Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod nano. You’ll know the iPod is restarting when the screen changes and the Apple logo appears.
  4. If this doesn’t work at first, you should repeat the steps.
  5. If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
  6. If this doesn’t work, you may have a bigger problem, and ought to get more help.
Aug 03, 2010 | Apple iPod nano
My ipod nano keeps frezzing how can you solve the problem?
Hello :
1: First make sure that your iPod’s hold button isn’t on. This is the little switch at the top left corner of the iPod video that you can move to “lock” the iPod’s buttons. If this is on, you’ll see a little orange area at the top of the iPod nano and a lock icon on the iPod’s screen. If you see either of these, move the switch back and see if this fixes the problem.
If the hold switch wasn’t the problem do the following :
2: Move the hold switch to the on position and then move it back to off .
3: Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod nano. You’ll know the iPod is restarting when the screen changes and the Apple logo appears.
4: If this doesn’t work at first, you should repeat the steps .
5: If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
If that didn't help , then you should take your NANO to the service .
good luck .
please rate !
Mar 30, 2010 | Apple iPod nano
I plugged in my i pod and came back a hour later and the screen was black and was frozen and none of the buttons would work
you will need to reset your ipod this will not delete songs. 1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Oct 21, 2009 | Apple iPod nano MP3 Player
I have an apple ipod 80 GB black. the problem is with the battery charge indicator.it is showing that it is full charge when it is not.help me out of this problem.
Try resetting your ipod:
  1. Push the hold switch to hold and then set it back to unlock.
  2. Press the Menu and Select buttons same time and hold for at least 6 to 15 seconds.
  3. Release the buttons when Apple logo shows.
If this does not work you might have a faulty battery and the only way to fix that is so buy a new ipod
Sep 24, 2009 | Apple iPod MA446LL/A MP3 Player
My Ipod Nano 4G won't open
  1. First make sure that your iPod’s hold button isn’t on. This is the little switch at the top left corner of the iPod video that you can move to “lock” the iPod’s buttons. If this is on, you’ll see a little orange area at the top of the iPod nano and a lock icon on the iPod’s screen. If you see either of these, move the switch back and see if this fixes the problem.
  2. If the hold switch wasn’t the problem do the following:
  3. Move the hold switch to the on position and then move it back to off.
  4. Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod nano. You’ll know the iPod is restarting when the screen changes and the Apple logo appears.
  5. If this doesn’t work at first, you should repeat step 4
Jul 06, 2009 | Apple iPod nano
Change language to english
You have to reset your iPod. (Note: This is for the 3rd generation iPod Nano)
To reset iPod nano:
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
- Make sure the Hold switch isn’t set to HOLD.
- The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
-Logan
Dec 22, 2008 | Apple iPod nano
Ipod nano 4G
Reset iPod nano
(if your iPod nano isn’t
responding)
Set the Hold switch to Hold and turn it off again. Press the Menu
and Center buttons at the same time for about 6 seconds, until the
Apple logo appears.
May 22, 2008 | Apple iPod nano
Help
Make sure that your iPod’s hold button isn’t on. (little switch at the top left corner of the iPod). If this is on, you’ll see a little orange area at the top of the iPod nano and a lock icon on the iPod screen. If you see either of these, move the switch back and see if this fixes the problem. If that doesn't fix it:
Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart it. You’ll know it's restarting when the Apple logo appears on-screen.
Jan 10, 2008 | Audio Players & Recorders
Help me pleeze
Apple iPod nano Logo
16 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
