Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Ice maker jambed-now no water
The icemaker was making noise all day and we found an ice cube jambed. after removing, it no longer works. we have water from the door but not into the ice maker. also it does not run. the red light is solid. the line does not appear to be frozen. filter new. i took it apart and find nothing broken. in door dispenser
  • saoax May 19, 2008
    I have the same issue with a Kenmore side by side. We had a jam in the ice tray and didn't know until water started pouring out the front of the freezer. Once we cleared the jam and freed the "teeth" that push the cubes out, we haven't had ice since. Help!
  • sstauss Jun 01, 2008
    It doesn't make sense that it would need to be primed, as I didn't prime it when new. Any way, I replaced the icemaker complete. It immediately filled and made ice and dropped the cube and refilled and froze. It doesn't drop the next batch of cubes. I removed the icemaker and heated with hairdryer to getr cubes out. I did this 5 times and every time the same, only 1 batch of cubes, the old icemaker will not even get water. HELP!
    Problem Solver:
  • 14 Answers
The ice maker must be re-primed with water to sense frozen ice in the tray, dump, and refill. Use a cup or glass to manually pour the water into the tray just below the top of the blades. It should freeze, dump, and refill.
Posted on May 29, 2008
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
My ice machine no longer produces any ice cubes? the machine is about 3 years old. Got it from Home Depot. Is this under warrenty? who should I call for repair service or what can I do to determine a...
If the filter is really bad it won't make ice becuuse the water can't get to it. A way just to check to see if the icemaker is working is to pour a small cup of water into the icemaker and see if runs through the cycle a makes a batch of ice, try the cup of water before you call anyone. If it makes ice then either you need to change the filter(which you should do anyway) or you have a bad water valve. If it doesn't make a batch of ice then your icemaker is bad.
Oct 31, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Icemaker not making ice. Green LED is ON, no
you have a dual water valve that sends water to the ice maker and the water in the door and it is very common for the ice maker side or the water side of the valve to go bad and on of them working properly and the other not
Apr 09, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
Icemaker makes Ice But doesn't dispense it.
Had same problem. Looked everywhere and found no solution i'm a not a repairman...they probably do not want to post so they can make 150 for a repair visit. At least try this first it may save you $$. Remove ice bucket from freezer. Remove 2 screws @ auger...remove cover and auger ....remove spring and large hex shaped shaft. heat the large shaft end with a torch and put it back in hot side toward motor until the motor end is not frozen. No torch you can use hot water...but that may freeze again.
This was happing because my flap to the ice was not closing all the way .
Manual for parts can be found here it shows ice maker parts on page 7.
Good Luck Kono
Aug 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
A very unusual 'croaking' frog like noise from the back of the freezer compartment. It stops if the freezer door is opened and starts again once closed. The freezer light switch is involved: With the...
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Jun 05, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Funny fridge noise, kenmore elite trio
Nov 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Firgidaire FRS20ZRG Side by Side Refrigerator/Freezer Ice maker not working
reach into the icemaker and with a finger pull up on the ejector blades on the icemaker watch the blades and see if they go all the way around
Feb 13, 2008 | Refrigerators
Ice maker quit - LG refrigerator model LFX25960ST, ice maker PN 5989JB0001A
I have the same problem.
Ice in the gears.
Splash from opening and closing the door when liquid water is present seems to be the logical problem.
I had cleared the ice before, thoroughly dried the icemaker and reinstalled it. It worked until I adjusted the icemaker to make large cubes.
I will reinstall it and see how long it last. I will also complain to Sear about the short life of this device.
Dec 27, 2007 | LG LFX25960ST Stainless Steel French Door...
Kenmore Bottom Freezer 596.71103101 Ice maker not working right
Did you find icemaker solution? I have the same unit. Ice maker worked perfect. Then moved to new house, icemaker stopped working. One day it worked (old house), the next it stopped (new house)!
Nov 13, 2007 | Refrigerators
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
325 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
