Question about Tefal 8746002 2Slice Toaster
Will not lock down - Tefal 8746002 2Slice Toaster
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 7 Answers
Have you tried the Etch-a-Sketch method ? (tip it upside down and shake it?!)
Turning it upside down to get all the crumbs out might help, or you might have to take it apart and find out what is blocking it - crumbs, or a foreign object such as a wire bread bag tie etc
Hope that helps
Posted on Sep 12, 2010
1999 ford Taurus knob won't push down far enough to lock, it pops up instead of locking
The screw you used is too long and binding the lock rod. Take the screw out and retest. If the lock works use a shorter screw.
Sep 30, 2014 | Ford Taurus Cars & Trucks
Why rear seat will not lock down to floor?
make sure your seated in front first before pulling back to lock in and make sure lock jaws are open to activate closure when comes down onto bar to lock into place. if not seated correctly in-front will be offline & will not line up as well
Jul 16, 2014 | 2008 Jeep Wrangler
How do you rewhy is my brakes locking down while driving?how do i rest the abs system?
You have water in the brake system, it boils and applies the brakes.
Different size tires will set a trouble code, but not apply brakes.
Jun 23, 2014 | 1995 Jeep Grand Cherokee
WHY IS FRONT SEAT SLIPPING
Check the seat rails for foreign objects. When you lock the seat in position, try pushing lever down to lock position. (If you pull up on lever to move seat, push it down) If it stays locked when lever is pushed down, check the spring that pulls the lever down.
Jun 12, 2014 | Chevrolet Silverado 1500 Cars & Trucks
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
1995 ford futura doors wont lock
Inside the door is an electric motor that pulls the door lock down to the locked position, either the rod has come off to the door latch from the door lock motor or the motor has failed. Remove the door panel and check it for power when the button is pressed for the power locks, if it gets power then it is most likely the motor that is the problem.
Nov 01, 2012 | Cars & Trucks
How to remove child lock
  • Press "Menu" on the remote control.
  • Press the down or up arrows to scroll to the "Setup" option.
  • Press "+."
  • Press the up or down arrows to highlight "Panel Lock."
  • Press the "+" button to select "Off." The panel lock is now remove
  • 2 Press the down or up arrows to scroll to the "Setup" option.
  • 3 Press "+."
  • 4 Press the up or down arrows to highlight "Panel Lock."
  • 5 Press the "+" button to select "Off." The panel lock is now remove
  • Read more: How to Remove a Panel Lock on a TV ' eHow.com http://www.ehow.com/how_7581284_remove-panel-lock-tv.html#ixzz3pC8PrE8F
    Feb 04, 2011 | Televison & Video
    To fix the control lock you hold down the control
    Holding down the control lock button for 30 seconds did NOT work for me.
    I went straight to Whirlpool.com and found that if you Hold down the
    END OF CYCLE button for 3 seconds, the control lock turns off and the
    washing machine is again operable
    Oct 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Down arrow in lock symbol on keyboard. what is
    That would be the Scroll Lock. Do you have a Scroll Lock key? Press it.
    Thanks for using Fixya.
    Oct 05, 2009 | Dell 0Y3740 Keyboard
    Whirlpool Quiet Partner II dishwasher
    I held down the heated dry button & it worked!
    Aug 26, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
    Tefal 8746002 2Slice Toaster Logo
    208 people viewed this question
    Top Tefal Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    paul
    paul
    Oscar Netto
    Oscar Netto
    Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
