Question about Samsung CLP-300N Laser Printer
Paper feed works only with full tray and some paper qualities. Whatt's the problem?
    Genius:
  • 1,478 Answers
I think you just needed a little more tension on the roller that pulled the paper in.
Remove the rear access door (see manual). Off to the left near the feeder roller you will see a spring. move the spring to the END of the plastic arm that it is attached to (if it is missing you have a bigger problem). If you have moved your printer around a bit, the spring may have slipped down on to the arm and is no longer sitting at the end. This will extend the spring another 1/16 of an inch, and that is all all. Your printer should now feed a single sheet of paper with no issues.
Take care.
Posted on Sep 12, 2010
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
Paper doesn't feed from inside on XD 100 work center (10 years old, lightly used). Despite a full paper drawer, I get the "out of paper" error message.  I can copy by feeding through the back.
On this machine, the feed rollers might be worn down.
Not seeing the machine and by the description. there can also be other possible problem areas, deep in the machine itself.
Does the paper feed partially out?
If it does not, are there paper black scuff marks where the rollers were trying to feed the paper.
Can you hear the solenoids feed the paper?
If the paper does feed and seems crooked, it is possible the paper tray springs need to be stretched out just a little to push the paper tray plate more on the feed rollers.
Make sure the tray is completely up in the latched position so the feed wheels will touch the paper stack itself.
If you have a two paper tray, make sure you tell the machine what size paper you have for each tray.
Run paper in each tray.
Good luck.
Jan 15, 2010 | Xerox Office Equipment & Supplies
It won't print - says manual feed - load paper tray. Its a brand new printer (Brother HL-4040CDN) and the paper tray is full
The printer has an "alternate" feed, i.e., for envelopes and/or for special paper.
Open the door to access that "manual" tray, take some paper from the "normal" tray, and insert the paper into the "manual" tray.
Or, on the printer's controls, set the "standard" feed, rather than the "manual" feed, and press PRINT.
Nov 11, 2009 | Brother HL 1440 Laser Printer
Mp780 - Paper attempts to feed and fails Message: Load paper
Your paper feed source is wrong .Go to the printers control panel and change the feed source.
If all you do is 8.5X11 you can go into the maintenance tab and choose it to automatically change paper trays by selectin auto continuous feed.Make sure paper is in both trays of the same type and size.You will hear the printer try and grab the paper three times then it will automatically switch to the next tray.
Jun 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer prints from manual feed but not from tray.
you need ot open up the papper tray and more the laser down then it should work
please rate my helf i need you to i am a exert
Apr 20, 2009 | Brother HL-2040 Laser Printer
Paper in tray but message says paper tray empty
HP officejets are notorious for problems with paper feeding...
Try the solutions (ignoring the ones about tray #2) from this solution... They're all the same sort of printer feed mechanism.
http://www.fixya.com/support/t878735-printing_error
... also something I noted with the K850 (the earlier model to the K8600).. some papers are less likely to be picked up than others.
I had to get some cheap A3 paper for that unit which worked better than Xerox branded, higher quality photocopier stuff. Sounds strange but if it works...
Hope that lot helps.
Feb 22, 2009 | HP OfficeJet Pro K8600 Printer
Paper tray won't feed paper & I get a false paper Jam code
This might work for you - it worked for me. HP paper was feeding crooked. Checked the "Paper Type/Quality" in the printing options window - mine was set to Photo Paper. When I changed it to Plain Paper, the paper fed evenly. Hope this works for you.
Oct 31, 2008 | HP OfficeJet 7410 All-In-One InkJet...
"Out of paper" error message
i would try clening the paper feed tires and roller and if that dose not work i woudl replace them.also pull the paper tray out adn look in top of the printer where the paper feeds out of the tray to see if the is a peice paper is blocking the sensor that reads that the printer has paper.
Apr 03, 2008 | HP Photosmart 3210 Printer
Paper feed
Something is stuck in between the
tray and rollers possibly torn paper
in one of the corners
try with just a few sheets of paper
Once you remove the jam
wilthout breaking any plastic
parts it will work okay
Nov 16, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Samsung CLP-300N Laser Printer Logo
37 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
