I need a manual for a BEKO AA class 1000 RPM WMA 510W
Help how do i make the machine do a quick wash
Posted on Nov 07, 2010
We have exactly the same problem. The instructions in the manual do not work!
Posted on Jul 20, 2012
I need beko aa class 1000rpm operating manual
Hi Edwin, good day! For that specific brand and model, you can actually check this link for the file and download it from there:
Beko Automatic Washing Machine Installation Operating Instructions...
Sep 22, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Manua beko 5kg aa class 1000 rpm
most washers on a full wash cycle take about 60 minutes. It will take longer if you use a soak cycle with extra minutes because if you have a soak cycle and you set it for 30 minutes the total wash time will be around 1 hour and 30 minutes.
Jun 22, 2013 | Washing Machines
I have a beko aa class 1000 rpm and i want to remove the soap drawer to clean it. how do i do this??
I've just spent about an hour trying to do the same thing! After a lot of internet searching I found an answer. In the soap drawer there is a blue section with a small groove in it. Simply press this down & the drawer should slide out.
Hope this works with your model too!
Aug 07, 2011 | Washing Machines
How do i work the beko AA class 1000 rpm washing machine i cant get it on a quick wash and it wont rinse
Methinks you could do with a manual to help you!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
Good luck,
John C.
Apr 04, 2011 | Washing Machines
Washing machine flips the fuse box switch
Either the moter is jambed or timer is broken Disconnect power tip machine up and attempt to move belt manuallr it shouls with some resistance
Oct 12, 2009 | Washing Machines
Beko wma 510w will not spin
HI,
Try These
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion........
Jul 22, 2009 | Washing Machines
The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
Jun 28, 2009 | Washing Machines
Problem with spining during programs.
Try these solutions
I've just tested the water pressure pipe - pulled it up so that it was straight and that seemed to do it.
Jun 18, 2009 | Washing Machines
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Beko AA class washing machine 1000rpm WMA 510W
you put it on a 40 degree on the other side on the top left hand side i had the same problem for ages i couldnt help but laugh when i seen this
Jan 30, 2008 | Washing Machines
Washing Machines Logo
2,046 people viewed this question
Top Washing Machines Experts
