Question about Ricoh Office Equipment & Supplies
Ricoh AC104 Multi-function Laser Open Heat Error displayed on LCD screen. Manual says error means problem with Fuser - unplug, replug and try again. If it does not go away call a service tech. Until I clear this error the printer is basically dead. I have tried power cycling both throught the switch and by unplugging. Left the printer unplugged for a month hoping that by making it forget date/time etc it would also reset this error. No go. Machine forgets date/time but error does not clear.
  • 208 Answers
SOURCE: How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
Posted on Dec 20, 2007
  • 990 Answers
SOURCE: Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Posted on Dec 17, 2008
  • 58 Answers
SOURCE: receiving fax but not printing ricoh ac104
  1. check paper
  2. check modem, rj 45 may be in wrong slot, must be in "line" not "tel"
There are no error codes????
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 23, 2009
SOURCE: Dell Printer 926 cartridge error
I had the same prob..... I fixed it I took a clean soft rag sprayed Windex on it wiped off the ic type board on the front of the cartridge and also the board on the inside that the cartridge rest up against,,, turned it off and on put a copy under the scanner and kaabam it printed a month of pulling my hair out it works
Posted on May 22, 2009
SOURCE: ML 3561ND engine fuser. low heat error??????
It's in the onboard computer system itself. This is a pre-set by the company that is designed to force you to service the unit, buy parts, etc., whether you need them or not. It is dirty pool I agree, but unless you know how to get into the machine's maintenance menu to re-set all those factory settings, you are pretty much screwed.
This is a nice printer, and what Samsung has done here is a travesty to our trash problem. It will turn out that it is much cheaper to just buy a new printer and toss the one you have, ergo, you are throwing away a perfectly good working printer all because the greedy foreign corporation knows "Stupid Americans" will buy more and more.
There is a way to get in, but it is VERY hard to do, but you are welcome to try:
You can enter the menu in this way:
Start up the machine with push in the buttons "online" and "cancel"
--You will see the message "Download mode press online key"
Press about 15 times the "menu" key
--You will see the message "Uncheck consumable mode"
Press about 15 times "menu" and 5 times "enter"
--You will see "Press access key"
Press a few enters
Press 3 times "cancel"
Go to the EDC mode
-- you will see "press access key"
Press "cancel"
Go to maintenance and initialize the parts you like to reset.
(sometimes you have to try a few times; don't wait to long between each of the steps)
Your printers are NOT broken. It is all in the design and how the likes of Samsung, Sanyo, Toshiba, etc., have figured out a way to screw Americans over, why, it's the favorite Euro/Asian pastime, see how many times you can get brainless Americans to buy your product over and over and over and over, on and on ad nauseum.
I wish you all much luck!
Now, here is what I did, and I do NOT recommend it:
I went to Comp USA and found the floor model. I wrote down the serial number off the back, went home and called Samsung with that serial number - and I was told "Your printer is still under warranty, we'll send someone to your home to repair or replace" How lovely of them. And replace it they did. Now, I haven't gotten the error message with this one, but if I do, I'll do the same thing again. Screw me once, shame on you, screw me twice . . . . .
Posted on Feb 27, 2010
Get "open heat error" after one copy. tried unplugging
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Jun 03, 2010 | Ricoh AC205 All-In-One Laser Printer
Scanner locked
Disconnect the printer and leave scanner cover open (when printer is disconnected.) When connecting printer after 10 minutes shut the scanner cover before turning the printer back on and putting the plugs back in.
Aug 31, 2009 | Ricoh AC104 All-In-One Laser Printer
Open heat error
You have a fuser error. Unplug the machine and try again. If you still get the error, then you'll need to replace it.
Apr 20, 2009 | Ricoh AC205 All-In-One Laser Printer
Samsung scx 4200 laser printer diplay says open heat error"
Good Day Sir,
Your machine display "open heat error" it means there is a problem in the fuser unit. I suggest unplug the power cord and plug it back again. If the problem persists you must call for service.
thank you.
Apr 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
I am having CRU fuse error in my SCX 4216f. i changed cartridge but same error is there. please help
This is a "Fuser Error" -not cartridge. Unplug machine and then plug back in...if error returns, you have a problem with the Fuser (warm up error), and you need service.
Mar 08, 2009 | Ricoh AC104 All-In-One Laser Printer
Open heat error
From looking at the manual it looks as if you have a faulty thermistor. When warming up, it has to heat up to at least 60 degrees. If it stays lower then 60 degrees celsius for over 35 seconds and doesn't reach 60 within that time frame then that would cause the open heat error that is happening on your machine.
Feb 09, 2009 | Ricoh AficioSP 5100N Laser Printer
Receiving fax but not printing ricoh ac104
  1. check paper
Dec 15, 2008 | Ricoh AC104 All-In-One Laser Printer
CRU Fuse Error
you need to replace the toner cartridge and or the fuse on the toner cartridge
Apr 16, 2008 | Ricoh AC104 All-In-One Laser Printer
27 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
