I have a Splendide Washer/dryer combination model WDC1025. My initial assessment is that when connected in to power and the cycle selector is moved that nothing happens. I have read that the most common problem is a malfunction in the door latch switch mechanism. Is there a way to trouble shoot the switch/latch with a volt meter or ohm meter? I would like to know that I am ordering a part that will fix the problem.
  • jesse_willco Sep 13, 2010
    All this brand are front loaders or at least this model. The computer comes up with WDC1025 MCEE Combomatic 6100 and the plate on the back just says
    SPLENDIDE
    AMER
    WDC1025
    COD 4557027273
    PF1399280027
    I have called the distributor in Oregon and they tell me to contact a local repairman. No one around here has any idea about this machine. Guess I am the expert since I have pulled the top and back off it.
    Lots of the RV crowed have them in the RVs but I have had no luck finding anyone that knows about them. I guess that is good and says they don't break much. I also have learned that they are very pricey and I would not buy one new because of that since i live in a house and have room. My daughter has a house but cannot afford a washer or dryer at the present so I am trying to fix this one so she won't wear mine out!
    If I had a correctly working door switch/latch/lock I could compare. That might be the solution to order a new one and do just that. If it checks good then send it back and start over.
    Any and all ideas appreciated.
    Thanks
    Jesse Willcox
    Home 850.995.0976
    Cell 850.232.1338
    jesse.willcox@gmail.com
    willcoxj@bellsouth.net
    Chat Skype: Airdale
    Contact Me
    --- @ WiseStamp Signature. Get it now
  • 2,272 Answers
To disassemble your washing machine.There is a online site showing parts breakdown step by step. Click on this link directly and get the instructions :-- http://www.splendide.com/service/Combo_PartsBreakDown.pdf In the link also the other splendide washer model disassembly procedure is shown,But for your washing machine model its mentioned on page number 40. --------------- And to check the Door switch :------- Before testing the switch, remove the wires by using the needlenose pliers to pull them off the terminals. Be sure to avoid pulling on the actual wires themselves; only pull on the connector! Pulling on the wires can cause them to break or pull out of the connector. Make sure you know which wire goes to which terminal so you don't have a problem when you put everything back together.
With the switch free of its connections, set your multitester to read continuity. This is the setting on the tester that reads ohms and it is usually marked either RX1 or X1.
Keeping the probes touching the terminals, push in the switch. With the switch pushed in, your tester should display a reading of zero. Release the switch and it should return to infinity. If you do not get these readings or the tester reads infinity or zero at all times, then you will have to replace the door switch.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 13, 2010
    Top Expert:
  • Washing Mach... Master
  • 79,077 Answers
Is this a top loader?what is the model number? door latch switches are tested with an Ohm meter
Posted on Sep 12, 2010
Cycle selector knob clicks forward
PDF]Repair Manual - Splendide
www.splendide.com/service/TRAINMANM_Complete.pdf
WD802M (Splendide 2000). WDC1025M ... 6SOHQGLGH¥. Front Loading AutomaticWasher Dryer ... Description of Preset Wash Cycles / How to Set A Wash Cycle ONL: 21. Description of .... may appear to work well after repair is finished, but failure may occur at a ..... rear of the main top, then slide forward. Removing the ..
Sep 19, 2015 | Splendide 2000S Front Load Washer / Dryer
Wont finish drying cycle
Replace timer which is the main selector
Feb 08, 2015 | Splendide 2100 Vented Washer-Dryer
Wd2000 washer dryer combo timer advances around timer
If the program selector knob keeps turning, the machine needs to be reset.
Wait a few minutes for the drain pump to empty the tub, switch the washer-dryer OFF. Select one
of the Reset positions on the knob, then switch it back ON.
The link below will take you to the manual.
Hopes this helps.
http://www.splendide.com/manual_wd2100_2000s.pdf
Oct 12, 2014 | Splendide 2100 Vented Washer-Dryer
Wdc1025 splendide all in one combo,the dryer doesnt seem to get hot enought to dry??help
Do the clothes eventually dry over a longer period time than usual? If so, there are 2 possible problems.
1. Your dryer vent is nearly clogged
2. If it is electric, then the heating element is going bad.
GOOD LUCK
Mr. Tin Man
Dec 19, 2010 | Washing Machines
Need power button for Splendide Combination Washer & Condenser Dryer, model WDC1025MCEE or 6000
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 02, 2009 | Splendide Comb-O-matic 6200 Non-Vented...
Need operating manual for Bendix WDC1025 Washer dryer combonation
This is the same machine or nearly identical machine as the Splendide Comb-o-matic 6100, for which you can find the manual here:
http://splendide.com/request_manual.htm
Mar 31, 2009 | Dryers
2100 Splendide
The cycle knob rotating means the machine is in self diagnostics mode. You need to count the flashes that the led is giving, they are in 1 second intervals then repeats after a 5 second pause. Mine had 13 flashes and after contacting Splendide they say it was either a broken wire or a bad ETC sensor. With the help of a Ohm meter it turned out to be a broken wire. Mine is a 2100 vented by the way.
Jan 13, 2008 | Splendide 2100 Vented Washer-Dryer
Washing Machines Logo
274 people viewed this question
Top Washing Machines Experts
