Question about Casio DB360G-9A 30 Pages Telememo Watch
Can not remember how to install the batteries in a casio 1737 watch. It has a big battery and a small one.
    Welcome Back:
    Visited the website for 2 consecutive days.
You really need provide the *FULL* model, as there are a few in the Casio 1737 range.
Tip - wIth the back off, sometimes it is best to draw what you see, which can help when reassembling.
Removing the battery retaining 'cage' is not easy, until you know how. Under one of its corners, a small tag extends to help hold it in place. You need a magnifying glass to see the tag. Then move the cage into a position that it can removed.
A watchmakers small screwdriver helps with this.
You will not find these details in the User Manual!
Good Luck - Mike
Posted on Feb 22, 2016
escapement
  • 2334 Answers
SOURCE: new battery can not reset watch CASIO #2735 Atomic wave ceptor
Did you try this?:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Posted on Mar 28, 2009
  • 183 Answers
SOURCE: Changing the battery on My Casio watch module 1848. Two
The contact springs most likely have nothing to do with your screen being black.
The watch will have an "AC" or all clear function that needs to be performed. Check the back lid for AC or reset instructions. If there are no instructions there then you will have to visit a watch repairman/technician to have this procedure performed as it involves touching the AC pad on the circuit board to the back of the battery already installed. The circuit board is easily damaged if not performed properly.
Posted on Sep 17, 2009
escapement
  • 2334 Answers
SOURCE: Casio 1170 ATC-1200 watch needs to have batteries changed
Follow this link and download manual: http://world.casio.com/wat/download/en/manual/
Rate me, plz.
Posted on Jan 10, 2010
Testimonial: "The expert was most helpful in going to the manual I needed. I would recommend their help to anyone who needs help online. Thank you"
  • 15 Answers
SOURCE: Casio DBCW150-1 Databank watch (battery change)
DONT THROW IT AWAY THAT IS A COLLECTORS ITEM... You can get it taken care of at www.casiowatchrepair.com or call them toll free 877.659.0761 and have them take care of it, the watch will be as good as new.
Posted on Feb 23, 2010
SOURCE: Casio module 2273 battery change
did u ever figure out how to get the retaining clip?
Posted on Mar 13, 2010
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    How do I replace the watch battery for Casio DW-6900?
    mcdevito75 here, Casio uses an LCD crystal, Liquid Display Crystal, during a battery change any, any un do pressure remopveing or replaceing the battery could destroy the LCD. Take my advise, with a casio watch, look for a small watch repair shop in your area for the battery change. I"ve ruined many of my casio watches during battery change.
    Aug 27, 2010 | Watches
    I need to change a battery in a baby g watch
    mcdevito75 here, Casio watch with the LCD display, any wrong pressure on this display and your Casio is ruined, the liquid display can break very easily. BEST BET, look for a small watch repair shop in your area for this battery change.
    Jul 14, 2010 | Casio Baby-G Wristwatch
    Hi I have got casio babyg 163 model.i believe it needs battery replacement but cant find the battery model any help plz
    mcdevito75 here, Best Bet, look for a small watch repair shop in your area to cahnge the battery as any pressure on the display while changeing the battery on a Casio watch will break it.
    Jul 03, 2010 | Casio BG163-4V Wrist Watch
    Setting watch after battery replacement unable to set watch
    Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
    Make it as big as you need.
    Hope this tip helps
    R/
    David
    Dec 26, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    I have a casio a158w alarm chrono, the screen went blank, opening up the back, is the battery the big round thing in the middle that seems to be stuck in place??? it takes up most of the inner works of the...
    Yes, the big, round thing in the middle is the battery. To get it out you need to unclip or unscrew the contact covering it. When the contact is off you will see the battery number written on battery - buy exactly the same one and replace. After replacement you will need to set the watch manually.
    Jul 09, 2009 | Casio DW290 1V Classic Alarm Chronograph...
    I have a Casio DBC-60. I changed the battery because was not working for long time, but the watch stil is not working
    This is an old problem, but maybe this will help someone changing a battery on a Casio. Many Casio watches must be "zeroed out" by putting an pointed tweezers between the back of the battery and the AC terminal off to the side of the battery. On my old Casio Telememo 50, the AC terminal is in a very small hole just above the battery. On the Baby G force, it was in a wider opening, way at the edge of the watch. It has something to do with resetting the watches circuitry so it will operate again. Good luck!
    May 14, 2009 | Casio Watches
    I have changed the battery in my Casio 1604 a200 watch but now the screen isn't displaying correctly. Is there anyway of resetting the watch?
    I realise this post is 4 years old now but what the hell! If you open the back of the watch you will notice in the top left corner a small hole with the letters AC above it. Push something metallic into the hole to make contact with the metal backing. This will reset the watch and the display should then be fine.
    Shane.
    Apr 15, 2008 | Casio Watches
    Casio Pathfinder 2273 Reassembly Help
    Hi there these small springs sit under battery connector tabs (Below)copper colors tabs so that theres enoughe spring pressure, for your watch to run. Hope this makes sense and remember its just a watch so dont stress out, lifes short and you never now when that meteors going to come in and vaporize us.
    Nov 18, 2007 | Casio Triple Sensor Pathfinder PRG60-1AV...
    Casio DB360G-9A 30 Pages Telememo Watch Logo
    649 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
