Question about Mitsubishi WS-55859 55" Rear Projection Television
Tv speaker selection is greyed out in device setup
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Some one locked it out----the easy way would be to go to the option menu (requires 4 number code and original remote and is based on model number)
In the Option menu you highlight reset (or something like it) and press enter on remote----this will reset the set to the condition it was in when new in the box---set will turn off and come back on channel 3 in air band---you will have to select cable and auto program it but it should restore the speaker and all settings to default.
If you want the code for your set provide (confirm) model number and if this information helped rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Sep 12, 2010
Sound Appeal sound bar set up. Not getting sound from tv except tv's speakers. Help!
You have to check the sound setting of your tv. In most of the lcd tv there are two option that you can select. Internal speaker of the tv and external speakers while using sound bars or other amplification devices. Fist of all Check that setting. Check the link bellow to understand How to setup a sound bar to your tv.
http://electro-medical.blogspot.com/
https://www.youtube.com/watch?v=QQ3zFnnsiMs
Dec 27, 2015 | LG Televison & Video
How do I connect my Sharp HT-SB30 soundbar to Samsung UHD7500 TV
Should be able to use Bluetooth. Need to "pair" the devices (the TV and the soundbar). On soundbar, press On/Standby to power it on, press Input to select Bluetooth (pairing indicator blinks), press & hold pairing button until pairing indicator blinks quickly. Now go to the TV's setup menus: Sound > Speaker Settings > TV Speaker > SoundShare Settings, Add New Device=On, select the Sharp GT-SB30 from device list. If passcode, password, etc is needed, enter 4 zeros (0000). After the devices are paired. the pairing indicator on the soundbar should stop blinking. The pairing information should be retained so you only have to do this one time unless you do a full reset on the TV or soundbar.
Dec 23, 2014 | Samsung Audio Players & Recorders
The store demo mode is stuck on my insignia tv. the user guide says go to menu and then setup and select plug & play. however the plug and play option is grey and it wont let me select it.
Are you using an HDMI cable? Go to input and select TV. Then you should be able to access the Plug & Play option and be able to turn off the Demo Mode.
Jan 03, 2011 | Insignia 42" Flat-Panel Plasma HDTV
We dont have any sound in our acer computer
check sound properties in control panel->if greyed out u need to install the sound drivers.
If not check whetehr speakers are connected to right color port behind pc .also check in ctrl panel->sound and audio devices whether the right output device(speaker) is selected or not?
regards
abhilash
Sep 16, 2010 | Acer 90.00012.30B Computer Speakers
Computer does not detect a playback device after plugging in speakers
  • These are steps to ‘setup’ and ‘restore the "Audio Drivers.” Part (1) Click on the "Start" button, go to, and click in the (right, pane), the Control Panel. “Scroll to find, "Ease of Access (or) Speech Recognition Options.” Next, select Replace sound with visual cues." In the See also: (Category), click, on “Audio Devices, and Sound Themes.” Click on the, 'Playback' button, select the 'Active' Speakers.” Select, Configure to: "Audio channels" The (Speaker Setup) "wizard,” appear! Select (Test) click, the “Next” button. Follow the instructions. Next, go to the Properties to view: Device Usage: ("enable"), "Update Driver." Note: Click "OK" to all changes “Save and Apply!” Restart the computer. "Did this solution help?” If so, "Helpful Rating Feedback " appreciate , thanks paul7of9"*
Feb 13, 2010 | Insignia 2.0 Speaker System (2-Piece)
Sounds are not coming from the speakers. speakers are correctly connected. It shows the device status - this device cannot start (code 10)
Try this:
Click Start, select Run, type "services.msc" without the quotes and press Ok. Services window will open up. In that window, select the Windows Audio Service and the status and startup type of the same. In case the startup type is disabled, double click on it and select the startup type as Automatic. After that right click on this service and click Start. In case the Start is greyed out, click on Restart. Now check for the sound.
Jul 07, 2009 | Logitech Audio Players & Recorders
Haier HL26R COMCAST REMOTE CODE
what kind of comcast remote do you have please describe, black and silver, dta, and especially important what color is the OK/select button grey or red. If the Ok/select button is red the codes are 11034, 10768, if the ok select button is grey there are no codes, however you can use the search option listed below
step 1 press the tv button located at the top of the remote
step 2 press and hold the setup button located on the upper right of the remote until the tv button blinks red 2 times.
step 3 enter code 991 the tv button will blink 2 times again
step 4 alternate pressing the grey Power button then the tv button located at the top of the remote ( the tv will turn off when it finds the correct code)
step 5 press the Setup button when the tv turns off and the tv button will blink 2 times confirming the code is locked in
FYI this process can take quite some time but there is no direct code listing for the non dvr remotes.
Good Luck
Jun 20, 2009 | Haier HTF20R21 20" TV
Can't remember how to enter the codes
Hold down the "setup" button on your cinemate remote. All 5 buttons should flash. Select your device (TV CBL/SAT DVD VCR AUX)
This will stay lit. Enter your code and wait for your devices button to blink. AT that point hit the selected devices On/Off button. If your selected device turns off and back on, then Bobs your uncle.
Apr 03, 2009 | Bose Cinemate Digital Home Theater System...
No sound coming from dell A215 speakers.
Please follow the below steps.
Click Start + Accessories+ System Tools and select System Restore.
Click on any date where you remember sound was working and say next , It will restore Good Known Device and restart. You will find sound device working then.
Feb 01, 2009 | Dell A215 Computer Speakers
Mic
First, be sure to have the latest software from logitech's website, and the latest MSN.
Then perform the following:
Execute the audio and video setup procedure within MSN Messenger 7.5. This procedure will allow you to assign an audio input and audio output device, as well as assign the video device of your choice to work with MSN Messenger.
1. Launch MSN Messenger and select the “Audio and Vide Setup” option from the “Tools” menu.
Figure 1
2. Click “Next to begin the setup process
Figure 2
3. In the “Speaker Setup” window, select the output device you would like to use with MSN Messenger. This step is specific to speakers or headphones. If your speakers or headphone device is connected to your computer, select the device by using the drop down menu provided. You can also set the desired volume level and click “Play Sound” for an audio sample. Once you are comfortable with the your selected options, Click “Next”
Figure 3
4. In the “Microphone Setup” window, select your desired input device from the drop down menu provided. This selection will be specific to a microphone connected to your computer. If your Logitech video camera has a built-in microphone, this option will be presented as “Logitech Mic” with your camera model name in parentheses as shown below. If you have an external headset device connected to your computer which hosts a microphone, select the devices name or model number in the drop down menu. Once your device is selected, adjust the microphone volume level to your preference and click next.
Note: the microphone volume level may need to be tested in order to find a comfortable listening level for you contacts. As a starting point, try setting the level midway and adjust when necessary by re-executing this procedure.
Figure 4
5. In the “Webcam Setup” window, select the video device you would like to use with MSN Messenger. Once selected you should see a display sample in the window provided. You can also click the “Options” button to make camera specific adjustments. Once completed, click the “Finish” button to apply your changes.
Figure 5
6. Once you have completed this process, MSN Messenger should now know the audio input (microphone) audio output (speakers or headphones) and video device (webcam) to use when engaging in an audio and or video conversation.
Jan 07, 2008 | Logitech QuickCam Express Web Camera
Mitsubishi WS-55859 55" Rear Projection Television Logo
24 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
