Question about Frigidaire Freezers
How do you put gas back in them? - Frigidaire Freezers
    Sergeant:
    Novelist:
  • 193 Answers
This is difficult if you are not a refrigeration mechanic. Refrigerators and freezers made for home use do not have a service valve built in from the factory. Someone would have to braze a fitting into the suction line. Once that is done you would need a set of gauges and a tank of refrigerant (freon). The problem is, refrigeration equipment doesn't just need "gassing up". If it is low or out of freon, it has a leak in the system. If you "gas it up", it will leak out again. Refrigerants are too expensive to keep adding to a leaking system.
Posted on Sep 13, 2010
I have a gram freezer, I cleaned motor on condenser fan, and now it works in the laid down position but not upright?
you should never lay freezers of fridges down as it puts the refrigerant gas in the wrong place. The compressor is a pump, and it pressurises the returning gas in the condenser and turns it into a liquid, this is the 'high pressure side'. The liquid is pumped to the evaporator inside the unit, where there is spare air volume, and the liquid turns into a gas and goes very cold. This is the low pressure side. Your refrigerant liquid is in both places.
Turn it off and leave it upright for 24 hours to settle. If that doesn't fix it, you will need an engineer to empty the gas by sucking it out and then refilling it with new gas.
Dec 17, 2015 | Freezers
The green light is not coming on and it has been seating for about 2 years do you think i need freon
The light and gas level are not related. Does it come on at all? Check the power and fuse etc. first, then thermostat and compressor before gas level. If it needs gas, any leak MUST BE REPAIRED and a new drier fitted before putting new gas in
Apr 23, 2014 | Freezers
1999 kolpak walkin freezer not staying cold
Is the compressor cycling on and off? Is there any oil around fittings at components? Gas is the last thing you put in a refrigeration system. You need to find the leak before you put any more gas in the system. Hope this helps good luck.
Apr 08, 2014 | Kolpak Freezers
Freeze back up timer3beeps
signal means freeze cycle is longer than 60 minutes. Look for: stuck float, water valve leaking water into the sump, Hot Gas Valve leaking hot gas into the cold side of the refrigeration system. Start there.
Mar 06, 2014 | Hoshizaki Commercial Freezer KM-500MAH
I have ice buildup in the lower right hand side of the freezer in the back behind the baskets
Haier are a bad brand, the unit has cooling fin frost up and will not allow air to pass through the cooling plates, defrost the unit for 2 days with door open and restart, if all good after that, keep doing it, if not, its lost gas and needs the bin. Quality items deliver lengthy trouble free operation, sorry but I put Haier in the Daewoo class, Kelvinator or Westinghouse next time, its worth that little extra. Regards Russ
Jun 11, 2011 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Carpingani 161 wont freeze --plenty of gas in machine
if there is gas in it. no frost buid up and the evap coil isnt crested all the way across. then you have a blocked filter. your gage will give an inconsistant reading when the filter is blocked. may read normal but other times will give a higher or lower reading. try changing the filter. the other thing i see is the compressor maybe too weak for the freezed. very common that the manufacture has put a small compressor that may only work adequetly for a few years.
Aug 01, 2010 | Freezers
It sounds like running but its not cooling
Two reasons for not cooling 1 The gas has leaked out. You have to request the technician to check the same. 2 Thermostat switch/dial is not put on cool. Put it on the max cool or the highest number if numbered
Jan 27, 2010 | Freezers
Punctured gas line/ uses R-12
not very easily. Most freezers have the evaporator and condenser inside the wall of the cabinet and you cannot access them. If the puncture is in the condenser you can put in an exterior condenser however the parts break down for your model does not offer this option (:
Apr 08, 2009 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Used frigidaire
look around the back of the freeze and at the bottom you will see a small black compressor .Put your hand on it and if it is running you will feel it vibrating. If it vibrating but running very hot them it means you have no gas in the system so the freezer won't freeze. If the compressor is cold and not running then it could be eaither the relay on the compressor or the board on the front either way you will need to get an engineer in
Dec 11, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezers Logo
190 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
