Question about Dryers
Fridgidare Dryer Model #GLER34IAS2/Serial #XD40311703: dryer runs for about an hour then kicks out the breaker.
  • 1,531 Answers
Check the main terminal block and make sure there is no shorted wires.There is also a chance that the heating element has grounded out on the cabinet frame. causing it to draw to much power yet still dry clothes
Posted on Sep 12, 2010
Dryer kicks circuit breaker off after a few minutes running.
Hi gel937
Replace your thermostat, it is defective causing the dryer to overheat and kick the breaker
Mar 13, 2013 | iPhone Apps
Electric dryer runs for 10 minutes aand kicks out the breaker
You probably have a breaker that cannot take the draw of the dryer. See if a slow blow breaker is available.
Sep 24, 2011 | Dryers
Fridgidare dryer model GLGQ2152ES3 runs but does not heat how do I get inside front or back to check the ignitor. It doesnt light (i think)
ok, you can remove the small screws below the kick panel below the door on the front. that will gain you viewing space to watch and see if the ignitor is even glowing, if it is then you most likely need gas valve coils, or to turn on the gas.
if the ignitor is not glowing at all you will need to do some testing on the safetys and thermostats within the dryer. they are all closed at rest so you should have continuity through them. there is the operating stat on the air duct blower housing in the front of the dryer. there is also a hi limit that is on the rear housing of the unit that you will need to remove the top of the dryer to view and gain access to..
those dryers have been a pain and the rear hi limit is especially susceptible to poor venting practices so very common today, and the higher operating temps caused by the poor venting..
best of luck..
May 20, 2010 | Dryers
GE Profile Model#DPSB513EBOWW Breaker kicked to
Have you reset the dryer breaker also. Even if doesn't look tripped turn off then back on again.
Feb 01, 2010 | Whirlpool ET8CHEXSQ Dryer
Gas dryer tripping breaker when plugged in.
I have the same exact problem. Dryer works great....when empty. Put wet clothes in and 3 or 4 hours later they are as wet as when I started. I am going to kick the piece of junk to the curb and go get a GE dryer right now.....I suggest you do the same.
Oct 16, 2008 | Whirlpool LGR8648 Gas Dryer
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
Fridgidare Affinity washer door won't open after wash cycle
Try the following site for full information on unlocking Dryer -------
http://www.freepatentsonline.com/4908957.html
Sep 14, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Dryer problem
ck vent system to outside also ck the vent hose behind dryer to be sure it is not being mashed flat when pushed back..while you have it out ck to see if cord connection screws are tight loose screws can cause cord to overheat and melt insulation causing short..if breaker trips immediately suspect dryer if runs for a time before kicking suspect weak breaker
Aug 09, 2008 | Whirlpool WED5100SQ Front-Load Electric...
Kicks off circuit breaker
make sure your breaker is high in amps, at less 50 amp breaker
Jan 30, 2008 | Estate TEDX640JQ Electric Dryer
Dryers Logo
Top Dryers Experts
