How do I set up the security on my linksys wireless router?
    President:
  • 1,851 Answers
All you have to do is log in with the browser you use at the linksys' settings page, locate the wireless section and at the security settings set up a password. A good idea it to do all this procedure while you are connected through an ethernet cable, so if something goes wrong and you have to try again, not to loose the connection with the router.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Sep 12, 2010
Coda qoy
Sir
Checking or verifying the wireless settings of your Linksys Cable Gateway is important when connecting wireless devices to your network. This is the best route to take if you are unsure of your gateway's wireless settings.
The wireless settings that you need to take note of are:
  • SSID
  • SSID Broadcast
  • Wireless Security
To check the wireless settings on the Linksys gateway follow the steps below:
Step 1:
Access the gateway's web-based setup page. For instructions, click here. If you are using a Maccomputer to access the cable gateway's web-based setup page, click here.
Step 2:
Click the Wireless tab.
Step 3:
Look for Wireless Network Name (SSID). It is recommended to change the SSID to something unique.
Step 4:
Click the Wireless Security sub-tab and take note of the current Wireless Encryption Level and the Wireless SSID Broadcast if it is set to Enable or Disable.
If Wireless Encryption Level is set to No Encryption, this means that the wireless security on the gateway is disabled.
If Wireless Encryption Level is set to 64 Bit Encryption or 128 Bit Encryption, check the value under Default Key and take note of the Wireless WEP Key that corresponds to it.
I hope Your problem is Linksys router Problem is solved by now, In case You still need Linksys Router Help Then I Suggest you follow official Linksys Router Support URL Website mention below :
Linksys Support
Or
In case You still need online Linksys Router Support Then follow us On for Linksys Router Support
Mar 27, 2014 | Linksys WCG200 Router
How to blocked the wireless
You can change the wireless security settings on your router so that no one can connect to your wireless network.
To change the security settings, you will need to open the setup page of the router.
First connect the computer to the router with the Ethernet cable and then change the wireless settings.
See Linksys router how to
Jan 05, 2012 | Linksys Wireless-G Broadband Router
Set password on linksys router
Connect the computer to the router and open the setup page. Go to Wireless tab and click on Wireless security sub tab. Change the security mode. See Linksys router How to
Nov 16, 2011 | Linksys Wireless-G Broadband Router
Lost my wireless connection on linksys wireless g wrt54g v.4 router help.... called linksys wants to charge 39.99 for a quick fix plz help
My friend,
Please reset the router by pressing the reset button for at least thirty seconds.
Open the setup page of the router with 192.168.1.1 from Internet Explorer.
Username=leave this blank.
Password=admin
Router setup page will be displayed then.
Click on the basic wireless settings .
Give the network name(your choice) and channel =6.
Under wireless security settings .
Click on the security mode should be WPA.
Put a security key.
Save settings.
It will start working wireless .
Saved your 39.99 $
Regards:-
Amit Awasthi
Dec 12, 2010 | Linksys Wireless-G WRT54G Router
I have a linksys wireless-G broadband router (3 1/2 years old). Which for some unexplained reason dropped the security passcode and is now unsecured. It otherwise is working fine. How can I set a new...
The encryption settings is configured in the wireless settings in the Linksys Router. Login to the Linksys with a browser and enter the configuration URL. To secure your wireless router from unauthorized access, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
Sep 07, 2010 | Linksys Wireless-G Broadband Router
Lost installation cd cant connect to wireless router wrt54g v8 linksys router need to know how to get it connected to my laptop
If you configure the Linksys wireless router with encryption and you configure your wireless card in your computer with the router's encryption settings it will secure the Linksys wireless router and allow your computer to connect to the Linksys. Please click on this link and follow my instructions to secure your wireless router :-
Jan 06, 2010 | Linksys Wireless-G WRT54G Router
Connecting new linksys n to our brother mfc685cw wireless printer. Printer will not read new linksys n router
For isolation purposes, you may want to test the printer through the Linksys router via Ethernet cable and see if you can print if it is wired to the router. From there, configure the wireless printer to match the settings on your Linksys router. Once done, try printing again wirelessly.
Tips:
1. Make sure that they are on the same LAN segment. By default the IP address of the Linksys router is 192.168.1.1. so you may want to configure your printer using 192.168.1.2 for them to communicate.
2. Make sure that the wireless settings on the Linksys router match the wireless settings on your wireless printer. Check the SSID/Wireless Network Name and Wireless Security. All wireless settings should be the same for them to communicate wirelessly.
Jul 12, 2009 | Linksys WRT160N Wireless Router
Router
there is a possibility that the router may initialy have not been setupproperly, try to check on the articles I made on the link below and youmay get this one going, even with wireless security and all.
Setting up your Linksys router for Cable ISP
Setting up your Linksys router for DSL ISP
Setting up your Linksys router to have wireless security.
if you have other questions just let me know.
Nov 02, 2008 | Linksys WRT160N Wireless Router
Bad Roomate
You can do that by accessing the setup page of the router.
You can follow these steps on how to change the name and put in a security.
Checking the Wireless Settings on the Linksys Router
Step 1:
Access the router’s web-based setup page. For instructions, click here.
NOTE: If you are using Mac to access the router's web-based setup page, click here.
Step 2:
When the router’s web-based setup page appears, click Wireless.
NOTE: If the screen on your router’s web-based setup page looks different, click here.
Step 3:
Look for Wireless Network Name (SSID) and if it’s still set to "linksys", change it to something unique and take note if Wireless SSID Broadcast is set to Enable.
3698-009.png Step 4:
Click Wireless Security and take note of the current Security Mode.
3698-007.jpg If Security Mode is set to WEP:
NOTE: In this example, WEP 64-Bit is used. To know more about Wireless Security, click here.
3698-013.png If Security Mode is set to WPA:
NOTE: In this example, WPA-TKIP is used. To know more about Wireless Security, click here.
3698-015.png Step 5:
Click 3698-017.png.
Or you can go to this link. if you can see the images.
Jun 18, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
