Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
The shaft that the blade goes on to is bent. How do I seperate it from te crankshaft? samika1963@yahoo.com
  • 183 Answers
The shaft that the blade attaches to IS the crankshaft. You might be able to find a shop that is willing to straighten the shaft, but it is somewhat expensive. At my shop that repair would be $120 to $150. Most shops would not be willing to straighten a crankshaft and would only recommend to replace the shaft....probably a $200 to $225 repair. Sorry.
Posted on Sep 13, 2010
5-h-push mower has bad veberation blade is on tight
bent blade, bent crankshaft, blade not balanced are all possible causes for vibration.
If you sharpened the blade recently try rebalancing it.
You could have struck something while mowing and bent the blade or bent the crankshaft on the engine.
If blade is bent replace it. If out of balance, rebalance it.
If crankshaft is bent replace it, have it straightened or replace the engine.
To replace or straighten the crankshaft it will require engine tear down which requires knowledge and tools for small engines.
Apr 22, 2016 | Garden
What caused a vibration in the handle of my push mower?
a bent crank shaft or a damaged blade. have the blade balanced. should be good. unless you have hit something and damaged the crankshaft.
Apr 21, 2016 | Garden
I have replaced two radiators so far and every time the fan damage the radiator. when installing the new one there is a big space between the raditor and fan. What can be the problem
You may be missing some spacers and/or bolts to secure the fan properly. The fan could also be damaged. For example, the fins may be bent, the shaft is bent/misaligned, the fan blade assembly has seperated from the shaft, or the fan housing is bent or broken causing the blades to hit the radiator.
Feb 03, 2016 | Cars & Trucks
Poulan self propelled 22in blade hit a rock broke tip of blade starts then stalls
Did you bend the crankshaft. To check this out remove spark plug wire and tip mower on it's side and turn blade by hand and watch the shaft the blade is fastened on to. There should be no wiggle motion what so ever and if there is it may be bent causing the engine to not operate properly.
Sep 27, 2014 | Garden
My 9053 volitation wont lift ground, i checked top blade it's not loose from metal shaft, it also wants to spin heavy to the right in circles. I just it so I'm learning
Had a similar model lasted 10 mins i broke this little plactic holder that seperates the blades i bent it the slightist bit and boom never flew again
Oct 16, 2010 | xheli 9053 Outdoor Volitation Metal...
I have a constant vibration when running my poulan pro self propelled 22 inch cut lawn mower. any solutions to the problem......
My guess is that you have hit something pretty solid while mowing. You have either bent the blade, bent the crankshaft, or both. To check for a bent crankshaft, set the mower up on a table or tailgate where the handle is on the ground and the spark plug is pointed into the air. DISCONNECT THE SPARK PLUG !!! You don't want to risk starting it in this position. While a friend holds the engine brake lever closed, and pulls the rope, you need to watch the blade bolt. If the bolt spins without wobbling, just replace the blade. If the bolt wobbles, then the crankshaft is bent. A bent crankshaft can be straightened by a reputable shop. Not all shops are will to straighten crankshafts. It is not a cheap repair.
Aug 23, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Pull to start, smoke comes out and motor binds
Sounds as if the mower has run over a large rock prior to what you are describing, you have a definate sheered pin on the crankshaft, causing the smoke(completely out of time).
You need to take the top off the engine 2 or 4 philip screws on the top plastic shroud, the pull chord assembly removing the pull chord as one unit, 3 philip screws need to be unscrewed or 3 rivets need to be drilled out to unfasten this assembly, after this is complete you will remove the 3/4" nut that holds the "flywheel" securely to the main shaft(crankshaft) with a small hammer and the 3/4 nut lightly threaded on the shaft take a block of wood and lightly tap it this action releases the flywheel from the shaft...do you now see the woodruff pin sheared off in the machined groove on the shaft? replace that pin(shear pin,woodruff pin many names for the same part) take the old one to Ace Hardware or the like and get a new one, while it is apart and the plug of course is removed for safety sake of no start while working on it... turn the blade observe from the under carriage to see if the shaft is bent if it is I dont recommend repairing it replace the mower its an expensive job, if the shaft is ok sometimes the blade gets bent...replace the blade, Ace should have this as well bring old blade along when you go for the pin.
Happy Mowing!!
Jul 19, 2010 | Garden
I hit a rock while mowing and now the mower is vibratating badly? What do I need to Do?
You bent the blade. Therefore you need to by a new blade and install it.
Good Luck!!!!
Wayne
Jun 14, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
I hit something with , when i start the lawnmovers it goes crazy
The vibration is caused by a bent blade and/or a bent crankshaft. The first thing to do is to replace the blade to see if the vibration goes away. If it does not then you have a bent crankshaft. The higher rpm's is not normal but is probably caused by a timing problem caused by a sheared or partially sheared flywheel key.
Sep 14, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Yard Machines 22 inch mower, I dumped it on its top over the weekend, bent the blade, replaced it, now wont start, did leak oil out of the air filter, cleaned it out real well still wont start
if you bent the blade most likely you bent the crankshaft too.
Remove the spark plug and pull the rope and remove excess oil from the spark plug hole
check the spark plug for spark if you have none then a flywheel key is sheered a more in depth fix.
If you get it started you may notice a whole lota vibration due to a bent crank shaft or maybe not?
May 18, 2009 | Mtd 22" Yard Machine Push Mower
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
192 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
