Question about Panasonic Televison & Video
Panasonic SA-HT530 firmware
Is there any firmware out there that will allow my system to play avi disc? This ystem is a normal dvd cinema system
3 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: panasonic home cinema model sa-ht75
F61 error codes could either be IC501 or the regulator (IC502) in the power supply section.
For reference, pls view these two (2) posts here and here of similar concern on other models.
Other possibilities are:
1. fan not turning;
2. cold solder;
3. looses connections;
4. one of the other components/systems hooked up to the power supply is causing a fault (tuner, disc player).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 26, 2008
notsomot
  • 67 Answers
SOURCE: unlock code to unlock dvd player to play dvds from all regions
0082 0015 0089 0004 00F2 0033 0017 0010 0091 0013
make sure you have the disc draw open and enter the above code via your remote.
let me know if it works
Posted on Jan 10, 2009
  • 8 Answers
SOURCE: panasonic sa-ht95 home theatre Display shows
Replace traverse assembly.
Posted on Oct 02, 2009
My panasonic sa-pt460 surround sound system won't play any new dvds, does not recognise them in the system and says no disc, is this something that can be fixed or just because of the age of the syste
Sounds like it may have a hardware problem, specially if sometimes it plays one disc, and others not (I mean the same disc).
But in any case, check to see if there are any firmware updates from Panasonic, that may fix the not recognising new discs issue.
Usually firmware updates are done by formatting a USB pen with a manufacturer's tool and then booting the unit from that USB.
In some others just leaving the firmware file in the USB, and the unit will pick it up an upgrade.
Sep 21, 2014 | Panasonic Televison & Video
Region Code unlock for Panasonic "SA-BT737"
hi my panasonic bluray dvd player sa-bt737 is not displaying the picture, the sound is working great but i cant watch the movie even though i can hear what is going on in the movie. it has worked great in the past but i dont no what has happened please help me
Mar 27, 2011 | Panasonic Televison & Video
I have an LG HT752 TP home cinema system. I recently bought a Panasonic DMP BD 65 blu ray player and connected to LG system via optic cable. Problem is that when playing blu ray discs on the Panasonic...
That shouldn't happen, what kind of cable are you using? you should try an hdmi cable. its electronic so it either works or doesn't and there shouldn't be any lag at all.
Feb 28, 2011 | Televison & Video
My Panasonic SA-HT75 won't read any DVD/CD discs
The laser has failed. They all go this way. Throw it away and don't buy Panasonic next time.
Jun 09, 2010 | Panasonic SC-HT75 System
Unlock code to unlock dvd player to play dvds from all regions
Jan 10, 2009 | Televison & Video
Can I burn to disk a movie from my hard drive "avi file format"and play it in a dvd player
you cant play avi on normal dvd player,but you can convert avi to dvd format by use free softwere ( filmMachine )
Aug 10, 2008 | Panasonic Televison & Video
Panasonic sa-ht 530
hello.i've got a problem with my home cinema.is doesn't start .the light is stay red and the system is not starting ,.
Jun 04, 2008 | Panasonic Home Theater System System
DVD problems
You mention that it is a dvd player. Players wont record in True DVD format. Second the down loaded video is probably in the wrong format to transfer. you would need a conversion software.
Feb 22, 2008 | Televison & Video
PANASONIC Home cinema SC-DT100 - Flat cable connection
Hi, when you say it doesn't work, will it just not play/read the disc? Mine has to be "initialized" every time or it shows "No Disc". To initialize I turn the unit on then press and hold "Stop" on the unit and the "10-" button on the remote, then it works fine.
Aug 01, 2007 | Panasonic SC-DT100 System
Televison & Video Logo
116 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
