Question about Maax Calla 6042 Bathtub - 101058-000
Maax-novi whirlpool tub. Push switch botton and it does not come on and the button gets stuck. Have not uses it in a whole..This is a six foot tub.
  • 14 Answers
SOURCE: Not all jets working on Hydrosystem Whirlpool Tub
I believe the below web site can help you with your problem. The jets are more then likely just turned off.
I hope this helps.
sanray
http://www.hydrosystem.com/hydro4/options/components/
Posted on Dec 27, 2008
  • 659 Answers
SOURCE: find board for maax bubble-tub
You will probably have to go to the manufacture website to find a dealer in your area that you can purchase one from. Also, you can check online as well for specific parts for your tub. If often just google the brand and model number and start clicking on links to find what I want or need. Good luck to you!
Posted on Mar 23, 2009
  • 80 Answers
SOURCE: Cold air blowing into Maax Velvet 6032 Bubble Tub
The air coming from the blower will be cool, but should not be cold. Turn on the blower or bubbler feature (no water necessary) and go to the access panel ( as specified by install instructions), reach in and feel the tube connected to the blower, the tube should be warm, if not the heater coil is not working and the blower assembly needs to be replaced.
Posted on Aug 19, 2009
  • 123 Answers
SOURCE: Hi, We purchased a Maax 10 jet Whirlpool tub
http://www.maax.com/Upload/guides/fr/000_10050073_0305.pdf.......this should take care of what you need. If you have any questions just ask.
Thx
Ken
Posted on Sep 08, 2009
  • 120 Answers
SOURCE: no drain cut out in maax opera
It is very easy to cut the hole. It is also very easy to lose control of the drill and brutally gouge the tub. You need a strong drill and the correct size hole saw. Measure it carefully. You will only get 1 shot at this. Don't try to go too small thinking you can just make it bigger. That will not work as well as you think.
The hole saw needs to be a full circle of teeth with a center drill bit that sticks out further than the ring. You use a marker to put a dot on the tub where you want the drain to be centered. Then, you place the drill bit on the dot and slowly drill your pilot hole. When the ring of teeth make contact with the tub, they may want to skip and bounce. This will combine with your downward force to gouge big ugly chunks out of your tub.
I have scrapped many a tub by this exact procedure. You must control any and all bounce by firmly flexing your arms. You cannot allow any sudden upward or downward movements with the hole saw. You can give yourself a little more control by making the center drill bit as long as you can, but still firmly secured.
If all goes well, you will have the right size hole in the correct location. Sand or grind down the underside of your drain hole just a little. This will give your drain a flat surface to hug when you screw it together. A lumpy bottom may cause a leak. A thin bottom may crack during installation.
Take your time and you should do well. Good luck
Posted on Jan 20, 2010
Maax c02 error
[PDF]WHIRLPOOL BATHTUB OWNER'S MANUAL BAIN ... - Maax
www.maax.com/~/media/.../10050073_2009-04-17.p...
Translate this page Never operate the whirlpool system if there is less than 2". (5 cm) of water over the highest whirlpool jet (except for the back jets) or if the bathtub is empty.
Maax co2 error Bathtubs & Whirlpools Questions & Answers ...
www.fixya.com > Forum > Tags > co2 error > Bathtubs & Whirlpools
Maax bathtubs & whirlpools co2 error related questions and answers. Ask your Maaxquestions. Get free help from bathtub and whirlpool experts.
Maax bathtub c02 and e06 error - Fixya
www.fixya.com/support/t19321104-maax_bathtub_c02_e06_error
Aug 10, 2013 - maax bathtub c02 and e06 error - Maax URBAN 6032 HYDROFEEL AEROFEEL ... Jan 18, 2013 ' Maax Adagio True Whirlpool System.
How to Troubleshoot a Maax Tub ' eHow
Jan 05, 2016 | Maax Home
Can't turn on Whirlpool
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
Rod
US Parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
May 09, 2014 | Maax Home
Aerofeel does not work on maax tub model 105359-055
I asked the same question to the tech guy at customer service and he said no, because the water detector switch is actually a density switch, so the temperature really doesn't matter. The tub just has to be filed with water.
Feb 16, 2014 | Maax Home
I have the sa9592-02 bubble tub and my push button to start bubbles dose not start the moter
it sounds to me like the air button may not be working. You may have a small hole in the bellows which is the part that sends the air down the air tubing to the air switch in the motor. If there is not enough air being pushed down to the switch it will not activate the motor. You need a new air button or a new air switch in the motor. Pull the pump out and plug it into an outlet. take a straw and blow into the air switch while the pump is plugged in. it the motor turns on then you know you need an air button on the top of the tub. If the motor does NOT turn on then you need an air switch for the motor.
Feb 21, 2011 | Maax Calla 6042 Bathtub - 101058-000
Maax Velvet 6032 Bubble Tub - Is there only one setting for the air, the manual shows to push the button once for high, once more for medium and again for low, ours does not do this?
try holding the button down and see it will change. some systems are like that and other you have to push and release.
Jan 30, 2011 | Home
My bathtub jacuzzi wont work. I reset the circuit breakers but nothing. I filled the tub but nothing comes out of the jets
make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
Sep 30, 2009 | Maax URBAN 6032 HYDROFEEL AEROFEEL BATHTUB...
Thx
Ken
Aug 12, 2009 | Home
Maax Calla 6042 Bathtub - 101058-000 Logo
319 people viewed this question
Top Maax Home Experts
Donni Steen
Mike
James Feragola
James Feragola
Level 1 Expert
Are you a Maax Home Expert? Answer questions, earn points and help others
