Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Oiling a ceiling fan
I have a 1 yr ceiling fan made by Hampton Bay, and it is making a noise during operation, is it ok to spray WD-40 into the housing?
Thank you, Robert
  • 883 Answers
you can submerge it into a bath tub filled with wd40 if you want to....provided the ONLY thing wrong is a squealing shorted motor windings, right? It is hard to get oil into these bushings because of close tolerances and dust shields that hide the bushings. try it anyway...these motors are non-copper contacting magnetic induction driven, so near zero chance of spark-induced wd40 flame-up.
Posted on May 15, 2008
  • Marty marty May 17, 2008
    well...anything new to report?
My Hampton Bay ceiling fan has been making a sound - like a clicking noise - during every revolution of the fan, and at each of the 3 different speeds ever since it was installed.
Try a bit of chewing gum on each of the blades separately, it seems to be out of balance.By trying each individually and turning on each time you should find the imbalance.Cheers Michael....Australia
Jul 21, 2017 | Hampton Bay Dryers
How do I change the light bulb in a model 66266
It twists off counterclock wise. If that doesn't work, try spraying some WD-40 around the glass. Wipe off excess oil.
Jan 16, 2014 | Hampton Bay Dryers
The fan is making a "scratching" noise.
Hi steffmarin...
The scratching noise is one of two problems.
1.noisy fan bearings, cannot be lubricated, must be replaced (big job), or replace fan....
2. Plastic/rubber bearing up near the ceiling...the fan will be connected to it.
Sometimes when they get dry they get noisy.
You can spray the plastic/rubber bearing with a little WD-40 and it will hold the noise quite for a sure to "wiggle" the fan around after spraying to distribute the WD-40) evenly.
If your noise problem is this then problem solved.
Please take time to rate me
Jul 22, 2011 | Hampton Bay 52 In. Ceiling Fan, San Tropez
Getting lubrication into a ceiling fan is very difficult unless you take it apart, take it down and then turn it upside down.... Then spray WD-40 in around wwhere the fan blades hook up at. Then let it set for at least a couple of hours to let the lubricant work its way into the bearing. Turn it a bit and spraying more in every fifteen minutes or so will help to get it in there better.
Feb 27, 2010 | Hampton Bay 24002 Ceiling Fan
Similar problem: Does Hampton Bay Vaulted Ceiling Mount exist?
Ok so here is the deal. No there does not seem to be a Hampton Bay specific mount. The mount that comes standard in most of the Hampton Bay fans can handle the angle of most standard (read: small) angles. I do not know if it will be the case with all Hunter products, but the adapter for the Hunter fan that I replaced, worked with my new Hampton Bay. So now, I have from the downrod up is from the original Hunter fan. Hope this helps.
Sep 16, 2009 | Hunter Vaulted Ceiling Mount - Bright...
Hampton Bay fan bearing noise
its not the bearings sounds like you need to level the mount and that scraping it the fan blade mounting plate hitting the side of the 'case' that surrounds the motor assembly ive never heard of bearings in the motor going or needing lubrication other than what factory placed in them...remember Hampton Bay is the Yugo of electric appliances too
Aug 03, 2009 | Hampton Bay 24002 Ceiling Fan
Fan makes noise like it needs to be oiled.
No way to oil it. It is a sealed unit. Give it a small spray of WD40 that should relieve it. And will not hurt anything.
Jun 07, 2009 | Hampton Bay 24002 Ceiling Fan
Noisey fan
use WD-40 w/ straw spray every hole you can find
Dec 18, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Remote control, changed battery, still nothing
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
You can also try ebay for OEM replacement fan remotes for various brands including Hampton Bay...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
157 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
