Question about Kenmore Dryers
I have a Kenmre Model 110.62054100 that we have owned for about 6 years. Recently we needed to unplug the dryer to get it to work. We saw no error messages. Yesterday the unplug "trick" to start the machine, didn't work. (we knew this was coming) I have taken the front off and started resistance testing of parts and lines. When I got to the Thermistor it didn't move the needle at all. After reading some other comments on other models it seems that this could be the problem. What's your thoughts? Whatelse should I do? Can or should I use a jumper wire between the two wires to see if it works? Or is the fact that the ohms meter showed no movement good enough to order the part.
skrbin
  • 121 Answers
SOURCE: Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Posted on Feb 15, 2009
shinn8
  • 85 Answers
SOURCE: Whirlpool Model LE5720XSW0 (OLD) working for years
Probably your thermal fuse is bad. It is in the back just to left of vent outlet. Oblong white plastic piece with 2 wires attached.
Posted on Jun 07, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Posted on Aug 01, 2009
  • 112 Answers
SOURCE: Can I test dryer timer to see if its any good?
Check if you have 220 at the terminal block. The power is 220 hot to hot and 110 for each leg to ground. Generaly the has two speeds (220 regular and 110 for gentle). There are two heating elements that are ciontrolled the same way. The gentle cycle uses one leg and the heat ing elements use the other. The answer is how the dryer is set. Knowing that and using elmination you will find the problem in the controlls because the heating elements work or thew are open. The motor has two windings or it works or it works or has an open. I could not find a schematic but you may see it on the back oe a piece of paper in the controlls. I have faith in you finding the problem very quickly from what you said and what I told you. Good luck. Don't forget to cycle (turn them off and on) your breakers to make sure one is not intermittent.
Posted on Aug 17, 2009
aasc
  • 1606 Answers
SOURCE: trying to replace timer 8299771. Can't find my
On the new timer , you have 2 wires comming of the timer motor . The blue wire should go to one of these terminals on the timer itself . The place where there is ONLY a timer motor wire going to , is where it should go .
Posted on Sep 04, 2009
Testimonial: "Okay that worked perfectly. Timer works. Unfortunately, so does the old one."
I own a Kenmore clothes dryer, serial #ME2475807, model/stock #96573220. Recently the heat stopped working. It still spins the clothes around, but does not heat up to dry them properly. I think it needs a...
Unplug the dryer and take the back off
The backsides is where the element is located.
The back side components look like this:
Their are 2 limits mounted on the heater chamber:
More here
Sep 12, 2011 | Kenmore Dryers
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool duet sport will not turn on after error code
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 30, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
What does the F40 error code mean?
Here's where you can get a manual for your Kenmore dryer: Copy and paste the following to your browser:
http://www.searspartsdirect.com/partsdirect/modelHelp.pd?pop=flush&modelNumberId=18
I found two possibilities for an F40 code.
1) Error Code F40 is that the thermal fuse has blown.
2) The F40 error code is a communication problem between the machine control board and motor control board. A bad connection might or might not cause this.
If you post your model number, or download the owner's manual from the above link, you'll probably find out what it means, at least.
Nov 29, 2009 | Kenmore 67082 Electric Dryer
Bosch nexxt series 500. error eo4
I am not a repair professional. I am just a 78 year old
50 years. Therefore the washer or dryer ID doesn't
discovered that more than 4,700 people were asking
repair of my own and found an excellent video which
was so impressed with the video that when I saw all
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
advice on fixya.
Nov 29, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Wash cycle pause, flashing panel . During the wash cycle the it will pause and the front panel will blink back and forth. I can unplug applience and sometimes continue with wash. purchased 6/09
advice on fixya.
Nov 29, 2009 | Electrolux EW1000i Front Load Washer
I have a kenmore dryer Model NO 110.66512694 everything seems to work but no heat
advice on fixya.
Nov 29, 2009 | Kenmore 63942 Dryer
Our Iglis dryer is 2 years old and recently stopped working as well as it had been, we need to run clothes through the drying cycle 3-4 times before they are dry. Is there anything we can do?
advice on fixya.
Nov 28, 2009 | Whirlpool Inglis IP8200 Dryer
Kenmre dryer electrical connections
Yes. Ground and neutral connect to the same point in the breaker panel, and neutral is not needed for an electric dryer.
Jan 26, 2009 | Dryers
Dryers Logo
54 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
