Following power cut. Hoover Optima OPH714D will not start as dor lock light just keeps flashing. Help
5 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: Hoover oph714d - error code e16. What does it mean
Where in the program is this happening?
Posted on Sep 20, 2009
SOURCE: After a power cut my washer wont work the door
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Posted on Apr 29, 2011
  • 6277 Answers
SOURCE: My hoover nextra optima model
As a guess I would suggest that the mains cable has a break in it, just where the burn marks are, possibly due to flexing back and forth.
REMOVE THE PLUG FROM THE SOCKET.
If it was me I would cut into the cable at the burn marks, strip it back to expose the break, cut back the wires and I would carry out a safe but temporary join- but you are not me!!! You will need to have the cable replaced, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jun 28, 2011
  • 6277 Answers
SOURCE: hoover washing machine mod oph714d
Hoover's Error 3 indicates a problem with drainage.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
John C
Posted on Sep 11, 2011
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Apr 24, 2011 | Hoover Washing Machines
Manual for optima 616 hoover
Hoover optima 6 kg. When I close the door it clicks shut as usual but the door security light is flashing and it wont come on. Please help.
Aug 02, 2010 | Washing Machines
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
02 Kia Optima-flashing inside dash lights when starting vehicle
you have short between the radio and the interior light.
you need to get a diagram of the electric system and trace it out.
if you pull the fuse for the interior light, and run the CD what happen?
Dec 01, 2008 | 2002 Kia Optima
Flashing stop light
have you tryed unplugging it for 5 minutes to see if it resets itself?let me know-mike
Oct 31, 2008 | Hoover Washing Machines
INDESIT 1000 DOES NOT START
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
If this doesn't work you may have to replace the EMW. Should cost you around 60$
May 23, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
